New here.. A few minor questions I had..
Old Nov 3, 2011 | 02:42 PM
Big Zed's Avatar
First off, manual boost controller. All I need to do is get down to the wastegate actuators on each side so I can run hoses from there and T them at the MBC. But it's GETTING DOWN THERE TO THE BASTARDS that's the problem. Anyone have any ideas? I mean, if I pulled the master cylinder on the drivers side, I could get to it i think, but I really dont want to have to go that far haha.
Second, are there any "free mods" I should be aware of? Easy things I can do to better my car, etc. I'm relatively new to Zs and Nissans.
Third, timing. These bad boys are OBDI and last I knew, you had to set timing at idle with a timing light. What's a good number? Keep in mind i have a daily and I plan to regularly autocross the Z next year. So what would be a good, aggressive base timing angle?
Old Nov 4, 2011 | 12:45 PM
Woody75(Denver)'s Avatar
Timing is 15.
You should be able to "t" the wastegate hoses as they come up from the turbos to the intake pipes.
Old Nov 13, 2011 | 04:48 PM
Big Zed's Avatar
Yea, I know.. it's getting to the damn wastegate vac diaphragms that's the problem lol
Old Nov 13, 2011 | 06:11 PM
Pull the turbo outlet pipes, then there is a line going from the actuator to the solennoid and from the turbo inlet pipe to the solenoid. Just tap into the linto the factory line.
Just an FYI, MBC's are a pretty bad idea past 10psi without a tune to accomadate for the boosylt spikes.
Old Nov 17, 2011 | 07:24 PM
Big Zed's Avatar
How much boost would be safe was my next question, thanks bro. So which line are you talking about that I should tap into?
Niku-Sama
Aug 19, 2008 02:44 PM
skittle
Apr 19, 2007 03:28 PM
280ZX_AV8R
Aug 29, 2005 07:10 PM
Bryan Thompson
Mar 14, 2005 07:33 AM
mnelsonz
Jul 31, 2002 12:31 AM
