New Electrical Issue.
Old Dec 9, 2005 | 03:29 PM
domsgarage's Avatar
Tough Guy
Ok Peep dis.
All of a sudden the car wont start. It comes on electrically, then I go to turn it over and it all dies. Then if i slam the door, the electric comes back on normally. The battery is fine, and its not the alternator.
Also, I dont think my fuel pump is comming on, but I dont remember really.
It sems like a sort to me. But I dont know whats shorting it out. I took my amp out and disconnected all that jazz.
Also.
I had that issue a while ago with the accesories. I since then hooked my radio up to my battery which I also disconnected in hopes of finding out whtats going on.
The car clicks so I want to say its not the starter as well. Get back to me with anything.
Old Dec 9, 2005 | 03:38 PM
emo236's Avatar
confuzed member
start looking for loose wires around. Also, this happened to mea while back, it ended up being that the positive terminal on the battery was almost off, it popped off since I didn't tighten as much as I needed to. It was still making contact enough for all the accessories to work , but not enough to crank.
Old Dec 9, 2005 | 03:40 PM
domsgarage's Avatar
Tough Guy
I tightened up the positive. It was good.
Old Dec 11, 2005 | 12:23 PM
Jays_Z's Avatar
I had the same problem.heres a way to check it. Get a test light test the actual battery post. then check the battery terminal if it lights up your good if not you might have to change the battery terminal or at least clean it.
Old Dec 11, 2005 | 08:01 PM
91zxtt's Avatar
Check your main ground, then check the the positive and negative leads that run to the starter.
Old Dec 12, 2005 | 02:09 PM
domsgarage's Avatar
Tough Guy
P.S. When I slam the car door or rock it back and forth I get power untill I go to start the car. Then it wont turn over. It dies and I have to shake or slam the door again
Old Dec 12, 2005 | 02:24 PM
domsgarage's Avatar
Tough Guy
p.p.s. Did the test light battery and terminals are good to go.
Old Dec 12, 2005 | 03:19 PM
emo236's Avatar
confuzed member
how about terminals to the starter?
Old Dec 13, 2005 | 08:53 AM
nismo619's Avatar
that sounds kinda like my problem with my 1990 300zx i just bought for a steal price.. but with mine my ( BRAKE ) light and my ( LIGHTS ) are on light stay on until i rev up to about 1,700 rpm then they go off but i hear a weird buzzing sounds from the gas petal ? on the drivers side ? has any body got any ideas on what to do for mine ? since i cant start a new thread ....... hmmmm whats up with dat? >
Old Dec 13, 2005 | 12:55 PM
napoleonzheking's Avatar
F5 Hero
Check the relay.
Old Dec 13, 2005 | 03:34 PM
1SIKZ's Avatar
Dude you said that when you rock or shake the door you have power. Im not saying this is your problem for sure but id check inside your door. Check the grounds and all electrical. i used to work for a company that built window regulators and that happened a few times with some GM vehicles
Old Dec 13, 2005 | 08:50 PM
91zxtt's Avatar
Yea, what about the cables to the starter?
Old Dec 14, 2005 | 07:38 AM
domsgarage's Avatar
Tough Guy
Im going to check the cables to my starter. I had this problem with my brothers prelude about a year ago. I never got to check it out becuase it was so cold and since he got the car for free he just wound up junking it. It sucks becuase its really really cold out right now, which makes me question why all this crap happens when its starting to get cold.
P.S. For those who dont know, I did eventually get the door and the fender fixed, with that I got the entire car repainted to that blue sapphire color, it came out pretty nice. It could have been better, but Id say im about 90% happy with it. That happened last year around september, or when the cold weather starts to roll in.
Remember my drive shaft issue. Winter
Remember my alternator issue. Winter.
Whats up with all this.
This is probably a really stupid question, but is it possible, at all, for me to check those wires to my starter without having to get under neath my car????
Thanks for all the help so far.
Old Dec 14, 2005 | 08:11 AM
domsgarage's Avatar
Tough Guy
As im sitting here in class, doing nothing. Thats ok becuase im usually sleeping, i'm looking at the car repair guide for my Z. Am I right to say that the starter is located on the top of the car. In the right hand upper corner, under the hood of course. I have never had to work with a starter before. Im a starter novice. Werd up.
Old Dec 14, 2005 | 08:14 AM
domsgarage's Avatar
Tough Guy
I dont think its my relay to the guy who told me to check that. Ive checked them all over the past two months. Thanks though.
Old Dec 14, 2005 | 12:06 PM
CanyonCarver's Avatar
Jack Of All Trades
NO......
Old Dec 14, 2005 | 12:08 PM
Jack Of All Trades
In the right hand corner,
YES.........
Old Dec 14, 2005 | 12:10 PM
Jack Of All Trades
This is probably a really stupid question, but is it possible, at all, for me to check those wires to my starter without having to get under neath my car????.
NO................. .... Well kind of. You can check the upper endz coming off the battery from the top. For the lower endz, you need to crawl under.
Old Dec 14, 2005 | 12:33 PM
Riz Z Speed's Avatar
Administrative Brown Guy
You'll probably need another person to help you check those wires.
Tom Lauritzen
Dec 26, 2014 09:38 AM
ZeeDeveel
Oct 7, 2013 02:25 PM
jimbolo619
12
Apr 25, 2013 10:10 PM
mpv06c
Feb 8, 2013 02:12 PM
sparkycon
Oct 9, 2011 03:09 AM
