NEED help, ebrake and brake light won't shut off
Old Mar 11, 2013 | 04:28 PM
jeffny09's Avatar
Hi
I have a 1990 300zx n/a, I just bought it, and it has some problems that I'm working out one By one, my current problem is that the ebrake light and the brake light on the cluster will notmshut off, I adjusted the emergency brakes from the Reese rotors as well as at the e-brake,checked all e bulbs, I checked the fluid, I looked at the connection for the embrace switch and it has no corrosion, I'm lost and don't know where to go from here, this light is annoying and I'm about to just pull the bulbs out of the cluster and call it good. So before I do that I'm hoping I can get some help, thanks
Old Mar 14, 2013 | 06:26 PM
jeffny09's Avatar
No one knows?
Old Mar 14, 2013 | 07:35 PM
Rupe's Avatar
Horsepower Mathematician
Might take a while, relatively small forum.
Old Mar 14, 2013 | 07:39 PM
PredatorZ's Avatar
Alternator failing
Have your charging system checked, found a post on Nicoclub, similar issue, when the alternator starts to go bad those are common lights you will see. BRAKE and LIGHT warning lights on : 300ZX (Z32) General
Old Mar 15, 2013 | 06:27 PM
jeffny09's Avatar
Well I had checked in a while ago but I'll check again....thanks,,,,,ripe, I did not notice that , are there any other forums that I can look into?
Dirt Winston
Mar 26, 2013 08:26 AM
joel280zt
Aug 2, 2012 06:10 AM
Turbo86
Jan 15, 2007 03:45 PM
AlongCamePeter
Nov 4, 2004 07:51 AM
