Need help with 91 zTT
Old Aug 26, 2003 | 01:06 AM
Riz Z Speed's Avatar
Administrative Brown Guy
I've never had a problem with Citgo gas. Although I have noticed the difference between 92 and 93 octane gas. Some cheapo gas stations around here sell 92 octane as premium. Bastards. Sorry, I can't think of why your car is acting the way it is. My only suggestions would probably be...
Check your plugs like the one guy said. If your blowing black smoke then your detonating. You'll need to clean your plugs.
O2 sensor? Maybe one's bad or the wire's fried?
TPS? Maybe it's sending the wrong signal, running lean?
Have you recently installed a new filter element? Could the MAF sensor be damaged? Maybe it's sending the wrong info to your ECU?
Is the ECU providing you with any trouble codes?
http://www.ttzd.com/tech/diagnostictech.html
If you don't know how to check for codes, this link will help you.
Good job keeping us posted. Let us know what you find.
Old Aug 26, 2003 | 10:27 PM
What do you mean by rebuilt? Are you going to upgrade the whole bottom end? That's quite an investment. Also, a lot of work involved.
Did you try any of the stuff I suggested?
If you want any suggestions on where to shop, try the other thread I responded to. I'm feeling kinda lazy right now. LOL
https://www.zdriver.com/forums/showt...&threadid=6704
and others...
Old Aug 31, 2003 | 08:16 PM
[i]
Overall work done:
Got the radiator replaced at a local shop - $275
Changed the Spark Plugs myself - $90
Installed the JWT Pop myself - $98
Got the ECU checked & the engine www.z1motorsports.com - $35
Got the Turbo hose replaced at www.z1motorsports.com - $25 including labor
[/B]
Getting to drive your Z.....priceless!!!!
lol
Great to hear and happy motoring to ya!!
Old Sep 6, 2003 | 04:04 AM
Suggestion:
Get a lightened flywheel at the same time you do the clutch upgrade. Since you gotta drop the tranny anyway, might as well do it all at the same time.
If you plan on upgrading your radiator at all, before you do the pulley swap would be a great time to do that as well. Since you'll have to remove the radiator to install the new pulley.
Glad to hear you're up n running so well. See ya.
