N/A modifications?
Headers, 2 1/2" exhaust, Underdrive pulley, ECU, Water/alky injection, Nitrous and a electric fan should give you somewhere in the area of 135+HP. 222HP + 135HP= 357HP. Not bad considering you can do it for under $1,500.
You might even spank a few turbo'ed cars out there.
Originally Posted by FaYeZ_90NA
yo zgringo $1500 just the parts or with installation.
Still a good deal.
Originally Posted by ZXDude90
.......How much does a good nitrous setup run?
http://store.summitracing.com/defaul....asp&x=37&y=11
Headers- $580
Exhaust- $550+
UD Pulley- $200
Ashpec ECU- $200
Nitrous- $600
Electric Fan- $175
Total = $2305
These prices are off of CZP, Z1, Specialty Z and Ash's site.
Exhaust- $550+
UD Pulley- $200
Ashpec ECU- $200
Nitrous- $600
Electric Fan- $175
Total = $2305
Headers- $175
Exhaust custom built-$250
UDPulley-$60
Ashspec ECU $200
Nitrous- 2 kits off eBay, one Zex dry $300, and one wet $300. Only ended up using the dry kit.-$300
Electric fans- 2 12"- $70
Snow Water/alky injection- $200
Total-$1,255
The extra was used for a HKS ALC as his car was a automatic.
Originally Posted by rizzspeed
a little bit more and you could afford a front clip.
zgringo........ less the nitrous, what do you think with your mods, 250 net?
300 h.p. shouldn't be too hard, but I think you'll have to do some work to flow more air thru the motor. starting at the maf and working back thru the custom exhaust.
After looking at these engines with the intake plenum off, It doesn't look like it would be too hard to graft on a Eaton s/c, t/b & maf from, say a 3.8 liter ford engine. You can get these off ebay all the time for around $100.
Curtis Maynard
Jan 20, 2014 11:39 AM
I was thinking more in the $2500 area. How much does a good nitrous setup run?
