Misfire at higher rpm when warm
Old Nov 21, 2011 | 12:48 PM
Fourplants's Avatar
Hello everyone. I recently bought my z32tt and have been having a misfire when warm. At first we thought vacuum leak so we traced the system and fixed the leaks (3 of them) and no help. Then we thought boost leak, made a tester and tested everything seemed ok. Then I thought plugs. come to find out that the car has NGK iridiums. Did some research and found that the supposed correct plug is the NGK PFR6B-11B with a gap of 0.35 with my mild mods. My question is will the iridiums being a shorter plug cause a misfire at temperature? Should I go with the platinums? Never hurts to have another opinion. Thanks
Old Nov 21, 2011 | 03:00 PM
Rupe's Avatar
Horsepower Mathematician
There must be a reason for "requiring" a specific plug. Couldn't hurt to try.
Old Nov 22, 2011 | 03:08 PM
Big Zed's Avatar
What set of Iridiums are they? It's possible that they are too "hot" of a plug compared to the factory ones.
Also, dont assume plugs are the issue. It could be low compression, bad coolant temp sensor, etc.. If it's only missing when it's hot, then use that info to your advantage. What changes when the motor warms up? Then look those places for abnormalities.
Old Nov 22, 2011 | 05:26 PM
Check fuel pressure, you could have a bad FPCU which isn't turning the fuel pump on high.
Old Nov 22, 2011 | 09:04 PM
Fourplants's Avatar
They are the Iridium IX. Much shorter than the PFR6B-11B. Wouldn't the shorter plug create more volume in the cylinder causing a lower compression? I will also run a fuel pressure test when I install the new plugs. Thanks guys.
Old Nov 22, 2011 | 11:39 PM
I run the shorter iridiums in my TT, no problems with them.
Old Nov 30, 2011 | 03:55 PM
Big Zed's Avatar
Shorter plugs usually indicate a "colder" heat range. Having too cold of a plug isnt' necessarily bad. If you are, look at the tip of the plugs and see if they are sooty and/or black. This indicates an incomplete fuel burn. If they are white, then the plugs are too 'hot.'
Old Feb 19, 2012 | 05:25 PM
Fourplants's Avatar
Replaced fuel filter installed NGK pfr6b 11b, apexi afc neo and high flow cats to pass emissions test Dyno tuned 329.5 whp at 6450 rpm 345.6 ft lbs torque at 4800 rpm misfire is gone yay lol.
Old Feb 19, 2012 | 07:41 PM
Rupe's Avatar
Nice man congrats.
jofwolves
Jul 28, 2011 03:28 PM
patrickclee
Jul 22, 2006 05:16 PM
hjsouders
Apr 26, 2004 06:04 PM
280ZXTLVR
Mar 16, 2002 04:53 AM
