Lurch when A/T shifts from first to second gear
Old Jul 9, 2004 | 11:19 AM
MetalTear17's Avatar
I have had issues similar to that with my transmission, one thing that fixed alot is that it turned out a bushing was cracked around where the pedal actuates the slave and so not allowing full release of the clutch, although this may sound obvious it was not obvious at all that somthing like that would be causing the problem, so check everything out... i think the bushing was like $1.75 from nissan.
Old Jul 10, 2004 | 01:50 AM
OrangeZ32's Avatar
the 300's auto trannys are crap, there is a good chance you might end up scrapping it. How many miles are on your Z?
Old Jul 10, 2004 | 02:22 AM
CanyonCarver's Avatar
Jack Of All Trades
Originally Posted by roger749
I have a 1990 N/A 2+2 that lurches from first gear to second gear when the engine is cold. After driving for a few minutes, it goes away. I've been to a couple of transmission shops and they say there is no adjustment for this condition and that my transmission probably need to be rebuild. Any ideas?
Is your speedo / odo working properly? I had a problem like this before, tho not on a Z. It ended up happening after the speedo quit working and what it was was that the electronic pickup for the speedo went bad. This pickup also had wires going to the tranny ECU that worked to control the shifts. When I replaced the electronic pickup it solved the shifting problem.
Old Jul 11, 2004 | 10:48 AM
Riz Z Speed's Avatar
Administrative Brown Guy
A grounding kit is cheap and easy. Worth a try.
Ever check the Tranny fluid? Maybe a switch to a higher quality synthetic is in order.
Old Jul 16, 2004 | 01:54 AM
name brands like Redline or Royal Purple should be just fine.
weykool
Nov 21, 2010 09:31 AM
KENZ
Aug 18, 2005 11:13 PM
benz333
Aug 30, 2003 01:09 PM
craigerd2
Dec 4, 2002 10:52 PM
