Low idle problems
Old Sep 26, 2005 | 10:35 PM
forcedfedz32's Avatar
Low idle problems
Help! I just bought my first z32tt yesterday. Drove to New jersy to buy and drove it back 4hr drive. I the car is heavily modified, i started having problems when we got back home.. The car idles a little under 1rpms and stalls out quit often. My cousin owns a 97tt supra and knows quite a bit about turbo cars. He popped the hood and found a vacum hose that was leaking he pinced the hose and the car was iding fine, so he used a zip tie just for a day or 2 till he gets me a plug. Fixed the problem then later that day i took it to have the emmisions done and failed dont no why? I drove it home and it just idles so bad when it wants and puttered a little when i was giving it gas. I need some help guys. If anyone can help of have any suggestions i would apperecaite it. But i will say this, the 300zx tt is one hell of a car and im hooked. Alot of my friends own mustangs and was gonna get one but nothing beats a turbo import. I just feel like a million bucks driving this car.
Old Sep 26, 2005 | 10:49 PM
emo236's Avatar
confuzed member
I'm guessing your smog problems come from your vacuum leak. It'll cause your car to run rich a lot of times since the MAF is reading for more air than what is actually going in there and giving it the wrong fuel mix. Fix your boost leak. You probably have more as well, not just one.
Old Sep 29, 2005 | 10:31 AM
kevtt's Avatar
i also have an idle problem, my ride is a 93 NA and it idles i alittle under 1000 but then it kinda drops a little the goes up a little, you ca bearly notice it on the tach, but the car starts to shake a little bit,....but the weird thing is that when i turn on my AC..it idles just fine...i have n vacum leaks what so ever and now i dont know what the heck it is...any words from any of you guys??
Old Sep 29, 2005 | 12:45 PM
emo236's Avatar
confuzed member
sounds like a bad tps to me. also could be a bad aic.
Old Oct 5, 2005 | 09:04 AM
Brian's Avatar
I have a 93 and it does the same thing in idle but acclerates and runs great. It's just at idle. Could you please tell me what TPS & AIC stand for & where they are located.
Thanks,
Brian
Old Oct 5, 2005 | 01:02 PM
napoleonzheking's Avatar
F5 Hero
First thing, you guys should check all your plugs (not spark plugs, but connectors).. One day my car was ideling bad, REAL bad, turns out I had forgot to plug a few plugs back in in the back of the engine bay when i was working on it the night before... Check plugs, simple stuff you can visually see, then go for the TPS and other stuff...
Old Oct 25, 2005 | 07:18 AM
KevinH's Avatar
Have simuliar problem with NA
Thanks,
Brian
I have a '90 NA that just started stalling out when I push the clutch in. I have changed all of the plugs, months ago, and its not missing, so I don't think that it is the plugs or anything associated with the plugs. I have done some work to it recently, and have reset the ECU, just in case, but hasn't changed anything regarding my idle situation. I did recently take out some of the slack in the throttle cable when I installed the front strut tower bar, but I wouldn't think that this would have anything to do with my idle problems.
I assume that the TPS is the throttle Position Sensor and that its located on the driver side intake manifold at the butterfly. I don't know what the AIC is though.
Little help - Pls!
Old Oct 25, 2005 | 07:50 AM
emo236's Avatar
confuzed member
sorry about the AIC thing, I'm stuck on Supras still... The IAA is what I meant which is the Idle air adjustment.
Old Oct 25, 2005 | 12:34 PM
KevinH's Avatar
Amb Temp Sensor?
Can anyone tell me if the amb. temperature sensor is tied into the ECU and effects the TPS?
When I installed the new front body kit, I did not install the amb. temp. sensor. I really didn't know what it was. I noticed that the amb. temp reading on the climate control was -124. I thought that it had to do with a sensor inside the vehicle. I just remembered that I did not install that sensor, so I just hooked it back up and the amb. temp. inside the vehicle read correctly, so I was wondering if this could have something to do with my low idle issues as well. I still need to find a new mounting location for it and install it. I do that tonight after work.
Thanks!
Old Oct 25, 2005 | 07:40 PM
KENZ's Avatar
Silvered Hawaiian
now that is priceless
He popped the hood and found a vacum hose that was leaking...
my car does idle under 1k rpm.... look for the location of that loose hose, might solve your problem there.
Old Oct 28, 2005 | 09:08 PM
91zxtt's Avatar
I missed that line originally....
Common sense should tell you that the vacuum hose goes to something. It probably wasn't just a random hose that Nissan decided didn't need to go to anything. Fix it right....don't half *** it.
Post a picture of the hose and where it is in the engine compartment.
Since your bro owns a '97 Supra TT doesn't mean that he knows jack about these cars.
Old Oct 29, 2005 | 03:54 PM
emo236's Avatar
confuzed member
91 has a good point here. Supras are very different. They are an inline motor first of all and also are either a sequential or single turbo setup, not twin. They're easier to work on.
Old Nov 16, 2005 | 03:39 PM
bnsz32tt's Avatar
i have a 92 tt and it does the same thing. new o2 sensers will help the emmisions thing. as for the idle i havent messed with that yet. will let you know if i find somthing
MrStiggy
Oct 25, 2013 09:02 AM
maczero300
FS: 300ZX (84-89)
Jun 24, 2013 06:25 AM
hardenstine
Jan 29, 2011 10:02 AM
ToxicZ
Apr 4, 2007 12:05 PM
LittleblueZ
May 16, 2006 12:52 AM
