little help please
Old Jun 6, 2003 | 07:31 PM
drag_300japan's Avatar
well whens the last time that you did a tune up? plugs air filter? could be your tps sensor or air flow sensor. If your not very machanical you might want to get somebody to look at it.
Old Jun 6, 2003 | 07:36 PM
well whens the last time that you did a tune up? plugs air filter? could be your tps sensor or air flow sensor. If your not very machanical you might want to get somebody to look at it. Maybe your timing is off and you need to adjust your timing. bye a service manuel fromstrictly z it could help you learn a lot from your car!
Old Jun 7, 2003 | 11:50 AM
NISMO LMR's Avatar
Once again, me and my bud had the same problem with his Eclipse GS-T. It is the speed control, I know the problem, it starts out feeling like you let the clutch out bad or something, it's kinda spudery feeling, then you get up to about 1800-2000 RPM, and it just kinda chills there for a little, more spudering, then it just kinda gets normal again. then when you let off the gas its like you have an automatic cruise control. its basically a bad speed control. its like 25 bucks but you should take it your local mechanic to get a good diagnosis.peace
If at FIRST you do not SUCCEDE, LOWER your STANDARDS
