Knock Sensor
Old Apr 1, 2004 | 02:39 PM
blazindonkey's Avatar
Knock Sensor
If you were a knock sensor in a 1990 300zx n/a, where would you be?
Furthermore, is replacing the knock sensor something that's relatively easy to do, or should i have a mechanic do it for me?
Old Apr 1, 2004 | 03:27 PM
emo236's Avatar
confuzed member
The knock sensor is under the plenum on the block. And it's a VERY hard thing to replace and a very expensive thing to have replaced (abour $900). Some have just bypassed it because of this. Not recommending doing that, but it's an option.
Old Apr 5, 2004 | 03:35 PM
91zxtt's Avatar
Some people may tell you to just relocate it, but it's not a good idea. Nissan put it where it is for a reason. That reason is that it works best there. Just an FYI, I don't recommend relocating it. However; relocating it is more cost effective than replacing it and is better than disconnecting it. Your call.
Old Apr 1, 2005 | 09:51 AM
Lycan_leader's Avatar
hello you can exactly tell me where is located the knock sensor in an 300ZX '96 M/T VG30DE
thanks
Old Apr 1, 2005 | 10:16 AM
Shameless's Avatar
Originally Posted by emo236
The knock sensor is under the plenum on the block..
the upper plenum is the piece you see right on top of your engine.
Once the upper plenum is removed the lower plenum is visible it looks like 6 holes in a row.
if i am correct the knock sensor is below the lower plenum....
Old Apr 3, 2005 | 08:25 PM
91zxtt's Avatar
Does this help?
It goes inside the box.
Majere
Aug 24, 2013 06:27 PM
newzowner2
Nov 19, 2011 07:35 AM
noboosts130
Apr 27, 2011 09:51 AM
jfairladyz
Jun 21, 2005 07:50 PM
serg92
Nov 18, 2002 09:44 PM
