Knock/Detonation Sensor
Old 02-02-2006, 03:30 PM
Aphrodite's Avatar
Does anyone know where to get a Knock sensor at a good price? courtesyparts.com wants $142 for one
Aphrodite is offline
Old 02-02-2006, 05:06 PM
id personally save the money and get an apex-i safc II it will tune your car good (if done right) show you everything thats happening in the car, knock, throttle, rpm etc. and i think you can ebay them for like 150 otherwise new there like 350 sooo??? just a thought. probly not what you were looking for though.
snwbrderphat540 is offline
Old 02-02-2006, 05:32 PM
Aphrodite's Avatar
hmm, I might consider that... also I was wondering, could an improper signal sent to the ecu by a faulty detonation sensor cause the timing to be retarded, making the engine run a bit rough and lowering milage?
Old 02-03-2006, 12:41 AM
The Cake Is A Lie!
entropy31's Avatar
i'm pretty sure a faulty det. sensor in a TT causes safety boost. i'm not sure about an NA, but i would think that could be a possibility.
entropy31 is offline
Old 02-03-2006, 04:24 AM
japanz's Avatar
I will post these for you so you can use them for your viewing pleasure
http://www.conceptzperformance.com
http://www.courtesyparts.com/z32/index.html
If you decide you want to replace the knock sensor I would suggest a relocation to the rear plenum bolt and save yourself a $1500 bill from the stealership.
Assuming you ran codes and have a 34
japanz is offline
Old 02-03-2006, 10:26 AM
F5 Hero
napoleonzheking's Avatar
And just to throw it out there, Coz at Concept Z ALWAYS has cheaper prices than courtesy. I'm not "knock"ing (hehe get it?) courtesy or anything, I've ordered from them before, I'm just saying thats how it is.
napoleonzheking is offline
Old 02-03-2006, 11:54 AM
Aphrodite's Avatar
Yeah I have a code 34
Old 02-03-2006, 06:38 PM
japanz's Avatar
My second advice is to relocate to the rear drivers side bolt that holds the upper plenum to the lower plenum.
needed: A M8-1.25 x 100mm bolt, M8 lock washer, M10-1.50 nut, and M8 flat washer.
This is what some people do and it is fine. Others can argue this but unless you are taking apart the motor then this is a more than ample solution to get you boosted again.
Not such a big deal personally. Then I used $1200 to buy new wheels rather than let Nissan have the cash.
japanz is offline
Old 02-03-2006, 07:05 PM
Aphrodite's Avatar
Whats the advantage of relocating?
Old 02-03-2006, 07:48 PM
japanz's Avatar
The advantage is that it will save you a ton of cash. Some people do a resistor bypass, relocate to the back of the engine block or what I have mentioned. The sensor will work at least as effective as the original position. There are no performance gains at all, just in the pocketbook. I have never heard of the knock sensor being a problem for relocating it to the location I mentioned. Would you not rather spend the money on an ECU upgrade and injectors? Or something along that level. I would!
japanz is offline
Old 02-04-2006, 11:49 AM
Aphrodite's Avatar
Ahh... I see what you mean... its in the block , for some reason I was thinking it was accessable... but after a bit of research, I see... I may just try the 1Mohm resistor to see if it is indeed what is affecting what I think it is affecting, and prolly leave it in while I wait for my new knock sensor to get here
Old 02-12-2006, 06:37 PM
91zxtt's Avatar
I'm confused....how will a SAFC II help with a faulty knock sensor?
91zxtt is offline
97gtp
05-27-2014 07:14 PM
Majere
08-24-2013 06:27 PM
noboosts130
04-27-2011 09:51 AM
MO1
03-15-2006 06:18 AM
serg92
11-18-2002 09:44 PM
Quick Reply: Knock/Detonation Sensor
