JWT ECU Question 93TT
Old Jun 29, 2005 | 01:49 PM
craftm's Avatar
Will a 93tt JWT ECU work in a 91tt. I purchased a used one . The only upgrade I have is a K&N single filter. With the ecu in the car, it started fine, but after a couple of second it started to run rough and then shut of, I could keep it running if I gave it gas but it still ran rough. Put the old ecu back and it runs fine.
tag on the ecu says : P.o.p Upgrade package 93 300zx turbo fed AT
EZ323 TAF00
I did post the same message on Twinturbo.net
Need help thanks
Old Jun 29, 2005 | 02:38 PM
DanZ32's Avatar
Dan's the Man
You might want to give JWT a call.
If I recall correctly, the eprom changed in the ECU after 92 (8 bit to 16 bit I beleive).
Also, is your TT a 5speed or an automatic? Looks like the 93 ECU you have is for an auto.
Don't quote me on this. Again, you might be best to give JWT a call directly. They can surely give you a quick and easy answer.
Old Jun 29, 2005 | 08:17 PM
craftm's Avatar
Thanks Dan for the reply. I pulled the back off of the ECU to look around and found rust on the bottom of the module and on some the components I think this may be part of the problem. Do you know if the chip is the only differents between a standard ecu and the jwt. I have a standby ecu I can swap the chip into if that is the only differents . Thanks for your help
Old Jun 29, 2005 | 10:15 PM
b300z's Avatar
caught the z fever
when i read p.o.p. upgrade, i twin of twin filters and lots of air but not enough gas
is that right or do i just need to go to bed?
Old Jun 30, 2005 | 05:43 AM
CanyonCarver's Avatar
Jack Of All Trades
Goodnight.....
Old Jun 30, 2005 | 07:15 AM
b300z's Avatar
caught the z fever
ok...yea that was stupid
i think ill go back to bed now
Old Jun 30, 2005 | 10:54 AM
DanZ32's Avatar
Dan's the Man
Man, I don't know. I'm a scared when it comes to sensitive electronics like this. I would be afraid of damaging a chip/board in some way even if it was switchable.
Contact Jim Wolfe Technologies, best info always comes from the source.
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
domsgarage
Oct 11, 2010 07:44 PM
Denver93TT
FS: 300ZX (90-96)
Jul 12, 2005 08:18 AM
