irattic boost pressure????????
Old Jan 28, 2004 | 04:25 PM
emo236's Avatar
confuzed member
You're hitting safety boost. Safety boost will not let your car boost past 7 psi. At 14 psi...I hope you have an aftermarket ecu. The reason that you may be going in and out of safety boost may be that you're detonating. It sounds like pebbles in a coffee can. If that is so, You need to lower the boost immediately as you could do some serious damage to your motor. Here's a whole tech on why you could be going into safety boost:
http://twinturbo.net/ttnetfaq/FAQpages/safetyboost.html
Also do an ECU diagnostics and see if you get any codes to come up. Good luck.
Old Jan 28, 2004 | 04:41 PM
emo236's Avatar
confuzed member
It means the detonation sensor. If you look at the throttle cabble cover and go directly back about 2 inches or so, that's the connector to the detontaion sensor. The actual detonation sensor is quite a way bit down there...It takes A LOT of work to get to that.
Old Jan 28, 2004 | 04:52 PM
NISMO LMR's Avatar
Dude your missing an O2 sensor????!?!?!??! JESUS! Go to my "Parts list." post, and scroll down till you find the O2 sensor... Thats the cheapest I found. Good luck bro, peace foo's
Old Jan 28, 2004 | 05:01 PM
emo236's Avatar
confuzed member
You'll want to put that in as soon as possible. I doubt it's causing you're boost problem right now, but you'll have other problems if you don't get that done. Have you investigated that saety boost problem yet? Does the detonation description match what you're exeriencing? Does it go away after you shut off the car or take it easy for a little?
Old Jan 28, 2004 | 05:32 PM
emo236's Avatar
confuzed member
Cool, a lot of times that connector can be a problem...I'm glad it was the connector and not the sensor itself.
Old Jan 28, 2004 | 05:34 PM
91zxtt's Avatar
The knock sensor is a bitch to replace. Cross your finger that fixes it. You definitely want to get that O2 sensor installed. That could be part of your problem also.
Old Jan 28, 2004 | 05:41 PM
emo236's Avatar
confuzed member
It's more logical to just relocate your knock sensor than to replace it due to the fact that it costs quite a bit to do so. But it nearly takes an engine pull to get to the stupid thing.
Old Jan 28, 2004 | 05:51 PM
91zxtt's Avatar
I have to disagree with you EMO , but relocating the knock does not work properly. The knock sensor is basically just a microphone. The further you put away from what it's listening for, the less effective it will be. Plus, it picks up other sounds when you do this and may mistake it for pinging. If it is the knock sensor, just bite the bullet and fix it right.
Old Jan 28, 2004 | 06:25 PM
91zxtt's Avatar
Welcome to the world of forced induction performance my son!
Old Jan 28, 2004 | 09:15 PM
emo236's Avatar
confuzed member
Good I'm glad that it's fixed. And yes, forced induction is a beautiful thing. As far as relocating the knock sensor goes, it's arguable. Some say that it does what you say it will, other's say that it gives you some knock sensor protection...just not as much as the stock location, but it's worth it since you avoid a plenum pull. It's all a matter of opinion.
Old Jan 29, 2004 | 01:29 AM
Z_WRECKER's Avatar
Emo stop beating a dead horse already (91zxtt)....knock sensors are a bitch to get to, so once you are there i'd replace it anyway, no matter if it's good. i'll put that on my list of to do things once i do the swap...thanx guys you are the best
Old Jan 29, 2004 | 10:52 AM
emo236's Avatar
confuzed member
See the other post in general about this same toopic. I hope you get this fixed.
VanBruno
Nov 2, 2014 10:16 PM
76 2+2
13
Dec 12, 2011 01:52 PM
TheHolyGhost
Sep 27, 2006 04:57 PM
1SIKZ
Mar 12, 2006 11:39 AM
jtmny1999
Apr 3, 2003 07:40 PM
