High Oil temp n idle at start
Ok I no search search search. But I hav and came up with nothin for my oil temp issue during idle. I dont no if it only does this during a cold start since i havent had time to drive it but i assume so. When I start the car it idles at 1,500rpm's and the oil temp goes up to jus a pintch over half. And I mean right away. If I rev it a lil bit and then let off the pedal the idle will drop down to about 1,000 or jus a bit under but then it will go back up to 1,500rpm. So any ideas boys. my exhuast fumes smell a bit rich to me also. And the other day I think I got a slight back fire as well. Like a low pop pop
there is no oil temp gauge. there is one for water temp and one for oil pressure. oil pressure should come up on a cold start, as the oil is more viscous when it is cold. and you should idle a bit high when the car is warming up.
which gauge are you talking about? the one to the far left, or the one under the tach?
Ok I feel really dumb
Yes it was the oil preasure that I was referring to. But entropy31 made it clear that its just normal as the car warms up on a cold start. Its my first car and all and sometimes when I notice things that I didnt before I get really freaked out and think that theres a problem. And since its a Z I'd rather nothin ever happen to ma baby.
madkiwi
Jun 6, 2015 07:40 AM
challenger
May 23, 2008 12:53 AM
