fuel injectors
Old Aug 17, 2010 | 04:53 PM
hardenstine's Avatar
fuel injectors
does it matter what fuel injectors i get will they all fit or do i have to do the year or whether it TT or NA and all that stuff or can i use 96 or 93 in a 92
Old Aug 17, 2010 | 08:24 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Did you do any research at all before starting this thread?
Your 92 has pintle injectors, you cannot install the 94+ (or maybe 93+... either way, they're differentiated in the buying options) injectors without either 300Degree fuel rails meant to fit 6 new style injectors, or the updated fuel rails and a machined lower plenum. You'd also need the newer connectors. (And you absolutely couldn't just replace a few bad injectors with the pintle-less... you'd have to do the full retrofit.)
And yes, TT and NA matters. TT injectors are 370cc/min, NA are 259 or 279 cc/min. If you install TT injectors in an NA, car you'll run rich and likely run like ****; NA injectors in a TT car will run lean and likely detonate.
Seriously... all this has been discussed at length on here and TwinTurbo.NET.
Old Aug 17, 2010 | 09:50 PM
domsgarage's Avatar
Tough Guy
yeah bro, come on now.
when it comes to the lower intake. i know it needs to be machined for the newer style injectors, but my question is, can the lower intake from say a 93+ (late model 93s use the newer style) be used in an earlier model to make everything fit right? I know the timing belt pulley is on the end of the lower intake but maybe that doesnt matter?
I havent searched this, ill admit. But im going to eventually do the injectors on my motor and if i can just swap intakes id rather do that.
thanks
Old Aug 17, 2010 | 09:55 PM
You can certainly just get the newer lower plenum and it'll bolt in just fine... most people just find machining more convenient (I think there's a template floating around the internet somewhere or at least details that you can give to a machine shop to have it cut properly).
Old Aug 17, 2010 | 09:56 PM
domsgarage's Avatar
Tough Guy
i already have the lower plenum, thats why i was curious.
cool, thanks.
TeamRonin
Oct 6, 2009 10:24 PM
280zinkansas
Apr 27, 2004 10:26 AM
NwZXlover
Jul 29, 2003 10:37 AM
NwZXlover
Jul 28, 2003 08:52 PM
lifegrddude
Oct 29, 2001 09:44 PM
