fuel delivery problem
Old Mar 22, 2013 | 01:38 PM
ivandz's Avatar
Hello. Ive searched all over and no one has posted an anser to
Any similar problem so i decided to create a new post.
I hope this is the correct place for it i am new to this foruk
I have a 92 300zx na 2+2.
It has compression and spark
It has a new ecu( dont know if it needs programming)
But the problem is that it wont turn on unless i put
Starter fluid in the intake.
Fuel compression tested at 60 psi after fuel filter
I am lost this is my only car i have 2 full time jobs
I really need some ones help.
I cheked pump, filter . I dont know how to check fuel regulator
If it were to be the problem??????????
Or what it could be. But im sure it aint an electrical problem because
For it to turn on ill put starter fluid in the intake and itll turn but fie out
After it ends.
All i know is that fuel is getting past the fuel filter but not getting t
To wjere it should
Checked fuses relays
And also checked every injector and every single one is getting
Power.
Johnathon Lynch
Aug 10, 2014 11:37 AM
RoscoP
May 12, 2014 02:41 AM
suntlanume
Sep 27, 2011 11:25 PM
ZguyECV
Dec 30, 2010 02:33 AM
