Engine wont rev over 3K :(
Old Jun 4, 2008 | 03:20 PM
Drew2+2's Avatar
So my Z wont rev over 3000 RPM when in neutal and it bogs out the second i put it into gear and try to go.
Help would really be appreciated. Thanks.
Old Jun 4, 2008 | 03:31 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Search. I can recall at least two threads covering this issue. It'll be your fuel system.
Old Jun 5, 2008 | 06:25 AM
CanyonCarver's Avatar
Jack Of All Trades
Check the MAF. Any ECU codes?
Old Jun 5, 2008 | 01:02 PM
Oh yeah... MAS (a.k.a. MAF) or fuel system (forgot the MAS can cause that problem)
Old Jun 28, 2008 | 10:27 AM
sailorjason's Avatar
Are you sure its 3000 and not 2500 rpms? If it's 2500 rpms I can almost guarantee that it is your MAF sensor. More likely the MAF connector and/or associated wiring.
Old Jul 23, 2008 | 03:48 PM
3riCJbOi's Avatar
one sound fits all
hmmm my bet's on your air flow
i had a similar problem with my Z
couldnt rev over 3,000 RPM
soo i had my MAF replaced at the shop and it works fine now
you should get it check at the shop to know for sure
get the car diagnose and fix it yourself
Old Jul 27, 2008 | 07:15 PM
domsgarage's Avatar
Tough Guy
3 times
check your MAF
Old Aug 11, 2008 | 11:31 AM
Drew2+2's Avatar
So I discovered that everytime I clear my ecu the car runs perfect for about half n hour then goes back to not wanting to rev over 2500-3000rpm.
How do I check my MAF?
Old Aug 11, 2008 | 11:47 AM
What code is the ECU telling you?
Old Aug 11, 2008 | 01:53 PM
Drew2+2's Avatar
55 everytime
Old Aug 11, 2008 | 07:31 PM
KasbeKZ's Avatar
Pr0n Addict
is that your z with the jspec? nice.
you can look up in the online FSM how to check the MAF. just do a google search for "online 300zx FSM" and it's in there. i find it hard to navigate, but it's in there.
Old Aug 15, 2008 | 08:51 PM
entropy31's Avatar
The Cake Is A Lie!
pretty sure that pic in his sig is not his Z. it's the yellow '99 that seems to be the most common example of the '99.
Old Aug 16, 2008 | 07:05 AM
KasbeKZ's Avatar
Pr0n Addict
oh yeah i guess the plate and the black background kinda give that away
mcge8241
Jun 18, 2019 02:47 PM
300ZX4EVER
Sep 1, 2011 12:35 AM
thxone
Oct 3, 2006 08:24 PM
skupy
Oct 13, 2005 06:34 AM
85_2fast4u
Jul 9, 2002 09:37 PM
