engine noise
Old Jul 6, 2004 | 10:09 PM
jaffi's Avatar
When was the last time the 60k maintenence was done? Also, please tell me your using premium gasoline. If not, then you would get pinging and spark knock.
Old Jul 7, 2004 | 02:43 AM
OrangeZ32's Avatar
Yeah, Definately I always run premium in my car at all times, it's a Z you kinda should just outa respect for the car.
Old Jul 7, 2004 | 11:36 AM
91zxtt's Avatar
Have you noticed a difference in the overall performance of the car? You set the timing on these cars by turning the crank angle sensor. You need a timing light to do this in order to properly set the timing. It is unlikely that the timing adjusted on its own. Has your ECU picked up any fault codes? Pinging is caused by running too lean, i.e. not enough fuel. When was the last time you tuned it up....new plugs, fuel filter, air filter, etc?
Zedsdead
18
Jan 26, 2015 10:02 PM
scorpionp54
Mar 10, 2009 06:33 PM
Speed
Other Cars
Mar 21, 2005 04:54 PM
apollo
Jan 26, 2005 03:35 PM
Zpeed Racer
Sep 22, 2003 10:37 PM
