Cone filter question
Old Sep 1, 2005 | 09:22 PM
nka04a's Avatar
This might sound like a bumd qustion , but i just want to be safe. Do i have to worry about my cone filter getting wet driving it in the rain? Thanks for the help.
Old Sep 1, 2005 | 09:45 PM
bardabe's Avatar
Bad Speller
I woudl not drive in teh rain. and yes if there is puddles and Heavy rain.
Old Sep 1, 2005 | 09:50 PM
KENZ's Avatar
Silvered Hawaiian
any car would get hydolocked if it sucked up a lot of water, no matter stock or cone.
i have drivin my car many times in the rain a through puddles and nothing.
dont be paranoid unless you think your car is a submarine.
Old Sep 1, 2005 | 11:10 PM
Team7's Avatar
On my old car my filter sat right next to my front wheel on the inside, so it was really low. I drove through puddles and everything. The only way you can get hydrolock is if you are stoped in a puddle that totaly covers your filter up to the begining of the intake pipe so no air can get in, basically creating a vacume and then put down some heavy throttle. This question has been discussed on many forums for many different cars and you will hear varying responses but I have maybe head of one person who actually got hydrolock and it probably was contributed to something else completely but it just happened to be raining. Dont worry about it you have to be a submarine
Old Sep 2, 2005 | 10:44 AM
KevinH's Avatar
Shield
I installed a shield that covers to bottom half of my cold air intake filter on the bottom on my '90 Z32 2+2 just in case. I've been running a cold air intake on my '93 Z32 N/A coupe without the shield. I did use a tie wrap and pulled the stock flexible plastic air deflector to shield the bottom of my cone filter on it. Bot of these cars are daily drivers, and I haven't had any problem. You can get a shield for you cone filter (or make one) pretty inexpensively and have 'peace of mind'.
Old Sep 2, 2005 | 12:00 PM
CanyonCarver's Avatar
Jack Of All Trades
I did the exact same thing with mine with two zip ties, pulling the plastic up against the end of the filter. The shape of it appears to help funnel more of the air that comes thru the smaller upper fascia opening directly to the filter.
Old Sep 2, 2005 | 03:25 PM
nka04a's Avatar
thanks for the help guys. Ill try what KevinH did.
Sweets
May 20, 2009 10:30 AM
Darkmann
13
Jan 27, 2008 06:22 PM
crowthma
Jun 8, 2007 05:29 PM
Turbo86
Oct 20, 2006 10:57 AM
myxtaz
Oct 22, 2004 11:26 PM
