Changing from Narrow 2 Wideband 02 sensor?
Old Jan 17, 2008 | 08:44 PM
derekinthez's Avatar
I am running with a narrow band Autometer WB02 Guage (that does not appear to be worth anything, b/c it reads all over the map). In order to change to a wideband guage, do I need to purchase a Wideband 02 sensor along with the wideband guage (I plan to get the one with digital and bar graph readings). If so, do I need to buy the whole WB02kit or are there things that I can keep from the narrow band setup?
Old Jan 17, 2008 | 08:57 PM
yup. if you got a wideband O2 guage you need a wideband O2 sensor.
the LM1 and LM2 seem to be pretty popular these days. i was going to go with those if i ever got around to my stand alone build.... which i didnt....
Old Jan 17, 2008 | 10:45 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
... he has seen the LIGHT!!!
... well, he's seen the discolight for what it really is at least.
Welcome to the world of functional mods. Yes, you'll probably need a wideband gauge in addition to the sensor. The narrowband kit is most likely completely useless for your newly found sensible gauge.
Old Jan 18, 2008 | 01:18 PM
js9krcr01040's Avatar
Sept Z of the month
IIRC you can run a wideband O2 with the Autometer AF gauges. It will read and show up with the correct reading, but you might as well spend the money to get the fully functional numeric readout of the newer gauges.
red coupe89
Mar 1, 2012 07:28 AM
napoleonzheking
Nov 3, 2009 09:42 PM
xlpbodily
Jan 23, 2009 08:16 PM
snwbrderphat540
May 24, 2007 09:34 PM
jmmorriso
Oct 4, 2006 12:36 PM
