car is vibrating
Guest
Posts: n/a
hello
he said once he comes to a COMPLETE stop. If you rev a bit with the foot on the brake still holding the car still i bet it stops, and if it is in neutural or park i bet it stops too. My mom's 87 accord does it too. We just bumped the idle up to 1100 rpm and there is no vibration anymore.
but it idles high.
well the car IS 11 years old, so vibrating at a stop isnt the worst thing that could ever happen.
goodluck
MIKE
but it idles high.
goodluck
MIKE
Guest
Posts: n/a
Bad Vibes
Bad plug, bad injector, bad coil or coil connecter?
Check `em all. Cheers & good luck
P.S. If the vibration is worse with car in gear at idle, and gets smoother when you shift to neutral at idle,you may have a dead cylinder. Check above, then do compression test.
my buddy's GS-T did the same thing, we came to figure out it was the speed control, that is a part of the electrical system.
-Worst case:ECU/ECM needs complete replacing
-Best case: I am wrong, OR the speed control needs replacing,
(i.e. about 25 out of your pocket)
peace
peace
OR......
It also could be the throttle bodies are really dirty or are being partially blocked by something. I helped fix an Olds for a friend, removed the throttle body and found about a 2 inch carbon deposit build- up. Nasty-*** job. After clean-up, the car returned to normal. Idle and acceleration were renewed. Or it could be something else. lol Good luck, O and if it is the throttle bodies this should help....peace.
http://www.twinturbo.net/ttnettech/tb/tb.html
Guest
Posts: n/a
this happens in mine to. does it vibrate at start up? when i turn on the car, i let it sit for about a minute or two to try and let the vibration work it's way out. it also vibrates at stops, and one time the car died on me. i took it to the Nissan dealer and they said it was the alternator, so i replaced it and it still vibrates, but not as bad. i need help to! lol
J
Cali
ReVg30De
J
Cali
ReVg30De
Hrududu
Nov 21, 2005 12:56 PM
