couple of questions guys!!!??
Guest
Posts: n/a
well I have 90 z32 na. the thing is my engine were missing for 10 days. I asked that question before. I changed the spark plugs. and it kept missing. the crazy thing is I didn't take it to a shop. I just thought about taking it. I went to start the car in the morning to take it to a shop and the car start acting normal . the missing is gone car works fine so I decide not taking it to the shop .. it became normal I have no idea what happen. again afte couple of days it start acting up again and missing engine ,, loosing power. again it became normal now (crazy Z)) and I have been using it for a week with no problems. the questions are...
1-I am driving now normally and when the hit 2500 to 3000 RPM.the car slow down feels like stalling and after 3000 it just jump to normal it is more like stalling any idea's why it is doing that???
2- I 've been having problims with the clutch too . every thing is normal but all of a sudden the cluch wont work good it feels like I am only prssing half of it while I am stepping on it is hard to shift the gear almost like there is no clutch, but again snapping it couple of times I mean pumping it and it works fine. ??? why is that ????????
and sorry for talking so much .. lol ..
Well we know that the spark plugs are good! It could be a number of things. If you want to be able to do the work your self rathere than take it to the shop I would get a service manual. It has a wealth of info! What I would do is start the process of elimanation check all the hoses for cracks ect. The hard thing about this problem is that when you take it to the shop the car will run fine, then the second that you leave the shop it will act up!! try to find somebody that has a consult that you could hook up to the diagnostics port and drive it and see what it will tell you! Good luck
Guest
Posts: n/a
do you thing by resetting the ecu every thing will be alright ?? I don't kno what is going on but because the car get crazy oday and fine tomorrow .. I beleive all ellectrical things. but again I have no idea. so do u thing it is from the ecu ????? I have another question to .. I ask toomuch huh .. lol
when I turn on the ac again every thing is fine but when I cramk it to #4 , I mean full power of the ac . it acts up , the ac goes of an on and I hear clicking comeing where the ecu is. pasenger side under the floormat ???? again do you thing it needs to be reset ?? thanks guys yoiu are helpful.
