car alarm
Old Feb 19, 2004 | 11:32 AM
typeaproduction's Avatar
car alarm
what would be causing my alarm to go off randomly?
a short? loose ground? thanks for any feedback!
Old Feb 19, 2004 | 01:20 PM
91zxtt's Avatar
I had a problem like that. There was a short in the wire for the glass sensor mic. You could also have the sensitivity set too high. Does it go off when a car goes by, or does it go off at completely random times? If it's set off by cars, then turn down your sensitivity. If not, then try disconnecting the glass sensor. If it still goes, then keep looking. Check the ground wire as well.
Old Feb 19, 2004 | 03:48 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Is this an aftermarket alarm or the stock factory alarm?
91zxtt is correct if you have an aftermarket alarm. Stock alarm will be different.
Old Feb 19, 2004 | 07:08 PM
Z_WRECKER's Avatar
stock Z alarm sucks a$$....thats the first thing i took off after got the car, and in goes viper 800, which is prettty good bang for your buck
Old Feb 20, 2004 | 12:32 PM
yea its a stock alarm, .. where is the glass sensor located?
Old Feb 20, 2004 | 07:18 PM
Stock alarm won't have such accessories.
If you want to remove the alarm, you can do so without any side affects to the car.
Near the ECU, actually directly in front of it is a brace. On the underside of it is a little box held in by two screws. It'll have a blue relay attached to it. It'll also have it's own wiring harness coming out of it. It should be labeled:
CONT-ASSY
THEFT WARNING
P#
S#
L#
Should be a bunch of numbers in there. So, two screws, two harness and you're done.
Old Feb 21, 2004 | 02:37 PM
Z_WRECKER's Avatar
Amen!
Old Feb 21, 2004 | 09:03 PM
thankyou
Old Jun 22, 2004 | 12:15 AM
outkast19's Avatar
Wiring Diagram/??
Im Getting A Autopage 2 Way Remote Start Alrm. Which Means More Wireing Than The Average Alarm. Where Can I Get A Free Acurate Wirng Diagram For A 90 N.a?
Old Jun 27, 2004 | 10:07 PM
OrangeZ32's Avatar
Rizz's Link Page, just go to the Z Manual.
speedlimits
Aug 29, 2005 08:31 AM
MetalTear17
Aug 26, 2004 08:32 PM
Blue83zx
Jun 16, 2004 08:06 PM
jesusfreakz
Jul 11, 2003 05:52 PM
WagdogZ
Jun 12, 2001 06:48 AM
