blueish white smoke
Old Mar 1, 2005 | 05:25 PM
tt300z's Avatar
blueish white smoke
i have blueish white smoke just like the title says.. hehe..but i just wanted to see if anyone knows what it should be..please let me know..i am thinking it is a head gasket but i want your guys' input first before i spend the $75 on a new gasket set..thanks
Old Mar 1, 2005 | 05:31 PM
b300z's Avatar
caught the z fever
an oily seal somewhere
is it coming out of both exhaust pipes?
Old Mar 1, 2005 | 06:02 PM
CanyonCarver's Avatar
Jack Of All Trades
Is it all the time? I'd check compression first. oil-in-water?, water-in-oil? If it's just at start-up when cold, that's a sign of bad valve guide seals. If there's no oil/water mixture and compression looks good, I'd check the turbo seals first.
Old Mar 1, 2005 | 06:16 PM
SHWAZ300's Avatar
Sounds like a head gasket, but there might be a leak somewhere. Check your oil and if it looks "milky" caramel like then it might be coolant and oil. If not like canyon said it could be oil and water. I'd say go with what canyon said lol, but personally it sounds like a headgasket.
Old Mar 2, 2005 | 01:39 AM
tt300z's Avatar
well it is usually when i start the car but today my friend was behind me and noticed that it was doing it when i was at a stop..or reving a little bit
Old Mar 2, 2005 | 01:43 AM
tt300z's Avatar
oh yeah also just so you know my oil lines are leaking to my turbos so i think my turbos are going bad because they are sounding really rough and dry almost like there is sand in them so yeah i dont know if that helps any..
Old Mar 2, 2005 | 06:03 AM
Jack Of All Trades
Originally Posted by tt300z
oh yeah also just so you know my oil lines are leaking to my turbos so i think my turbos are going bad because they are sounding really rough and dry almost like there is sand in them .......
I would start there then. Maybe just fix the leaks and clean things up with brake parts cleaner or engine degreaser. A compression check will still be pretty conclusive as to whether your head gaskets are o.k. or not.
tomas1329
Nov 9, 2009 12:37 AM
ZXT83
Sep 10, 2009 01:09 PM
marc z
Apr 15, 2009 08:52 PM
c-murder
Oct 29, 2006 05:24 PM
Togish1
Sep 17, 2002 08:34 AM
