Bleeding air out of clutch
Old Dec 12, 2003 | 08:44 AM
tsefreeflow's Avatar
I'm Chillin
There are two spots to bleed. One is at the slave cylinder and the other is a spot in the engine bay area on the passenger side fender. Some say you can also bleed at the master cylinder too so this would make three spots. Get a jar and fill it like half way full and dangle a hose from the drain nozzle of these three spots and dangle it into the jar making sure the end is always submerged. Pump the hell out of the clutch pedal then have a buddy upen the drain valve on these three spots (one at a time) while you press the pedal to the floor slowly. Have him close the valve before you get there. He should see air going through the dangling hose. Repeat until you see no more air at any of the three spots.
Old Dec 12, 2003 | 02:24 PM
I'm Chillin
Your welcome. Yeah, your car looks pretty sweet. I like everything but the rear lights. I really like the way they are stock. Just my thoughts, but its sweet what you have done. I really like the interior. Late
Old Dec 12, 2003 | 10:14 PM
Riz Z Speed's Avatar
Administrative Brown Guy
If you'd like a step by step with pictures....
http://www.ttzd.com/tech/linestech.html
Old Dec 13, 2003 | 11:53 AM
emo236's Avatar
confuzed member
Rizz, I've decided that you are the link king! They're helpful, thanks!
Old Dec 15, 2003 | 08:18 PM
Yeah you're right, but the principle should be the same. I'm not at home at the moment, I'm in TN. So I couldn't bust out the owners' manual. There's one online, I'll see if I can find the proper link for it.
Old Dec 16, 2003 | 12:20 AM
There should be a bleed port on the clutch operating cylinder located on the transmission and another bleed port on what the manual calls the “clutch piping connector” which is located on the right hand side of the engine compartment, near the front, above the wheel.
that's the advice I got so it sounds similar to what tsfreeflow advised. I was just wanting to find something more like a write-up to follow.
http://www.300zx.co.uk/cgi-bin/manual.cgi link to online service manual
http://www.300zx.co.uk/cgi-bin/manua...fault&total=18 parts diagrahm for N/A
http://www.300zx.co.uk/cgi-bin/manua...fault&total=18 Bleeding procedure
There!! Whew! I knew I'd find it. Sorry I didn't mean to step on your toes there tsfreeflow or to negate your advice. I'm just trying to help out.
I'd book mark the original site there guys. Plenty of knowledge to be had.
Old Jan 11, 2014 | 03:30 PM
S.Fonzii32's Avatar
2+2 Clutch
I replaced the Master and the slave cylinder along with the whole clutch as well . I started having that same problem, i have a 93 2+2 n/a and i blead the slave and the other part on the passenger and the pedal still stays weak and stays down i dont know what else i can do.
raythenegr0
Nov 16, 2007 11:18 AM
280zx81
Apr 6, 2006 10:38 PM
numb1300z
Feb 24, 2006 04:12 AM
Skully
Jun 5, 2003 08:28 PM
ratedZ
Jun 6, 2001 10:40 PM
