battery 96 300zx convertible
Old Jan 16, 2006 | 05:26 PM
Riz Z Speed's Avatar
Administrative Brown Guy
replace it.
car batteries aren't that expensive. If it continues to drain, you either have a short somewhere or the alternator isn't charging the battery. Have your car checked out, not just the battery.
Old Jan 17, 2006 | 07:51 AM
tnkrstoyco's Avatar
Loves Going Topless
Mine did that, had a problem with the factory alarm and had it removed. Now when it sits for extended periods I unhook the battery.
Old Jan 17, 2006 | 08:42 AM
WhtFairLadyZ's Avatar
Take a voltmeter and tke some readings. See what your battery is before cranking...then crank it and watch it. After a little while turn the motor off and see if it falls and how fast. If the battery voltage readout doesnt jump to like 14 volts then you have a bad alternator and it is killing your battery. If it does jump to around 14 v. then turn around then drop very fast after turnin off the motor..then you have a bad battery that isnt taking a charge. Your car should be able to sit in one spot without cranking for a week ATLEAST without killing the battery. Granted you are not leaving your lights and stereo on 24/7 without cranking the car.
Old Jan 17, 2006 | 10:41 PM
Comorat2x2's Avatar
Originally Posted by zconvertible
my battery goes down within 3 days. I have taken it everywhere to get it fixed. except nissan dealer. what to do
What everybody else has said and avoid a dealer like the plauge unless you have no other choice. You're gonna pay through the nose for the same **** poor service you'd get anywhere else.
Sorry, I'm a little bitter towards dealers in general when it comes to service.
Old Jan 18, 2006 | 06:22 AM
I m not completely against goin to a dealer..just dont be ignorant. Go there with an idea of what is wrong and what it takes to fix it. I.E. An alignment isnt necessary to change an alternator...lol. Shops can charge you for stuff that isnt needed. Plus I take pride in DIY stuff. I like being somewhat self sufficient.
Mike0276
May 22, 2013 04:06 PM
miataZowner
May 20, 2012 09:27 PM
miataZowner
Apr 19, 2012 06:05 PM
mwest300zx
Apr 7, 2010 05:16 PM
Evan
FS: 300ZX (90-96)
Oct 15, 2004 10:46 AM
