Auto tranny problem on a TT??
Old 05-07-2005, 08:49 PM
PNK SLP Z32TT's Avatar
Hey,
This is the first auto car i have owned so i dont know if this is normall or not. My Z has a wierd problem - My car shifts fine from 1 to 2nd to 3rd but its when it tryin to go into 4th, It wont shift untill i hit 3k RPM'S or higher, then after that i will shift fine into 4rth. The other gears will shift around 2500 but not this one. The tranny was rebuilt 2 years ago
Could this be a problem??
thanks
-ben
PNK SLP Z32TT is offline
Old 05-08-2005, 01:26 PM
Administrative Brown Guy
Riz Z Speed's Avatar
do you have the overdrive engaged?
is there an ALC installed in the car?
aftermarket ECU?
Riz Z Speed is offline
Old 05-08-2005, 05:34 PM
aftermarket ECU?
No the car wasnt in overdrive, and i dont know about the ecu upgrades. I dont think so cause i havnt touched it. It looked stock when i looked at it
Old 05-09-2005, 01:29 AM
El Viejo
Zgringo's Avatar
I think what Rizzspeed was asking is do you have a HKS ALC installed, and if the button on the left side of your shifter handle was engaged.
First...on your passenger side under the carpet is a wooden panel. Remove the wooden panel, 4-10mm bolts and look and see if you have a HKS ALC installed.
On your dash on the upper right side it well tell you if your in OD or not. Push the OD button in, light goes out, button out, light on.
Zgringo is offline
Old 05-09-2005, 07:20 PM
the overdrive button should be engaged pretty much at all times.
What you're experiencing with the extended range of the rpm's is most likely because your overdrive button isn't engaged. that's like basically turning on and off your fourth gear. oversimplied explanation but that's the gist of it.
the hks alc is designed to firm the shifts of an auto tranny.
3XAZOWNER
07-14-2014 12:11 AM
studio110
06-09-2012 08:24 PM
thxone
04-10-2006 08:57 AM
TX_zx
07-11-2003 12:01 PM
Wolfe
12-01-2001 11:40 PM
Quick Reply: Auto tranny problem on a TT??
