91' cold running issue under load
Old Nov 4, 2007 | 03:31 PM
dcshd's Avatar
car runs fine after reaching operating temp. not very drivable cold--very bad when shifting 1-2 gear Any thoughts? Just had all new injectors and injector plugs replaced- egr passages cleaned out.
Old Nov 4, 2007 | 05:27 PM
KasbeKZ's Avatar
Pr0n Addict
check the basics like Otiny2 sensors and temerature sending units
Old Nov 4, 2007 | 05:28 PM
KasbeKZ's Avatar
Pr0n Addict
check the basics like Otiny2 sensors and temerature sending units. an ECU diagnostic is the first thing i would do
Old Nov 4, 2007 | 05:34 PM
dcshd's Avatar
would slow o2's give this type of problem and go away with engine temp. ?coolant temp sensor reads good.
Old Nov 4, 2007 | 07:17 PM
b300z's Avatar
caught the z fever
please check search first for a question like this. heres a thread with plenty of information concerning a poorly running Z. https://www.zdriver.com/forums/showt...ight=high+idle
also, we need more details to fully help you. is this just an engine problem, or are you having trouble shifting as well?
Old Nov 5, 2007 | 05:25 AM
dcshd's Avatar
Not a shifting problem. car only has a problem when cold---first 5-7 min. of driving then all of a sudden runs great. Initially when pullig out in first gear its not bad but as soon as you shift to second gear and let the clutch out it falls flat on its face and it does not matter how much your on the throttle. It takes a few seconds before it starts to accelerate at all. This also happens second-third gear shift but not as drastic. Any thoughts?
Old Nov 5, 2007 | 07:24 AM
cake872's Avatar
I could be rong but jus putting it out there. What size fuel injectors did u install. If there a big step up and your fuel pump isnt giving enough preasure then i think it can be a problem.
Old Nov 5, 2007 | 07:32 AM
b300z's Avatar
caught the z fever
Originally Posted by dcshd
Any thoughts?
read thru the thread i gave you
Old Nov 5, 2007 | 05:12 PM
dcshd's Avatar
thanks everyone for your help. turned out to be o2 heater bad
Gonzo
May 1, 2013 02:27 AM
pa312d
Dec 9, 2012 10:12 AM
Joncampbe
Sep 4, 2012 08:10 AM
richlkyl000
Nov 19, 2011 11:06 AM
Cavinder
Apr 16, 2010 02:04 PM
