Valve Cover Gasket replacement..HELP!!
Old May 23, 2011 | 08:55 PM
sidd's Avatar
Hi friends,
I recently bought a 91 300zx N/A. Its in pretty good shape.. I headed to get an inspection done on it.. and found out that it has a small Valve cover leak.. That guy gave me an estimate of $500 for the replacement including parts... What do you all think is the right price.. He says it not a bad leak, but as the car is in good shape its better we replace it before it hurts the motor.. I need your suggestion.. I live in Tempe, Az. If anyone knows someone around here who can do this job for less.. I ll be glad to get it done..
Thanks,
Sidd
Old May 23, 2011 | 10:11 PM
mark26z32's Avatar
500 dollars...WTF...Man you can do this yourself if you are at all mechanically inclined...You are going to have to remove your upper intake manifold (which is probably where the shop is charging the 500 dollars for) Its a pretty simple replacement...If you dont have the know how or 500 damn dollars, I would see if someone on this forum lives close to you that can help you out, and you can pay them some money for helping you...That shop will make about a 470 dollar profit off of you (Valve cover gasket set is about 20-30 bucks) for something that you can do by yourself or with the help of a friend. My honest suggestion, is to try and take it on yourself, but if you dont want to, try and shop around and find better deals, that just seems a little steep to me, but thats how shops make there money by raping there customers wallets. They get parts at cost or even lower and charge you double sometimes triple for the parts.
Old May 24, 2011 | 07:12 AM
sidd's Avatar
Thanks a Tonn Mark!!! I am dumb mechanically... I will also look around and see if someone lives around me. I am also planning to change all the spark plugs and the fuel filter.... Wat are the other things that can be done while I am getting this thing done?
Old May 24, 2011 | 08:34 PM
singdam's Avatar
easy
i have done this a few times and it really isn't that hard. $500 sounds about right cause it takes a long time. Here is 2 sights that will help out
http://www.youtube.com/watch?v=3ajnzB8pWpY
http://www.300zxclub.com/showthread.php?t=111696
I used this to show me how to do it. But it also shows you a coolant bypass which will help out the next time you pull it off. will cut your time by more than half. If you still have questions email me and i will give you my # so I can walk you threw it
Old May 25, 2011 | 02:45 PM
singdam's Avatar
easy
this isn't that hard of a job. $500 is about right but you can do it yourself. not really hard at all. Here is some sites you can look at that will help you out.
This should help out if not email me and i will give you my # to walk you threw this
Old May 25, 2011 | 02:51 PM
singdam's Avatar
easy
not really hard to do yourself. But $500 is about right. I did it and it cost me a little under 100 that is to include a bypass. Here is some websights that will help you out.
If you have any questions email me and i can walk you threw it
Old May 25, 2011 | 02:54 PM
singdam's Avatar
not that hard to do if you want i can show you how and $500 is right. It does take alot of time to do it. Look at these sights it shows you how too.
Old May 26, 2011 | 04:02 PM
sidd's Avatar
Thanks a Tonn Singdam... I watch the video and I really do not think I can do it myselfff!!
Z-EZ
Jan 11, 2014 04:19 PM
KasbeKZ
Nov 18, 2009 08:25 AM
Warpix
Jun 11, 2009 09:19 PM
duowing
Oct 5, 2007 12:03 AM
MetalTear17
Aug 10, 2004 11:48 AM
