ud pulley install question??
Old Jun 27, 2007 | 11:36 AM
NAIIZeater's Avatar
I couldnt find a thread that could help me with this problem.
i'm having trouble tensioning my accessorie belts after insatlling the new ud pulley. Any help would be good thanks?
Old Jun 27, 2007 | 03:59 PM
are you using the stock length belts? because the under drive pulley is smaller correcto? so there for, you might need shorter belts. but idk for sure, are you just having trouble like you can figure out how to tension them or are you properly doing the process to tension them but tehy wont get tight enough? also, you might want to try a search on twinturbo.net for this while your awaiting a better response than mine from other people. never had to screw with the belts on my Z32.
Old Jun 27, 2007 | 04:45 PM
Goofyz's Avatar
Yes,
you will need a set of under-drive belts. try
http://www.conceptzperformance.com/C...524.33.125.140
or some other place that sells them.
Old Jun 27, 2007 | 08:30 PM
91zxtt's Avatar
Yes, the OEM belts are too big. You need the UDP kit; which includes smaller belts.
Old Jun 28, 2007 | 12:12 AM
or you could just measure the belts length and width, then go down to NAPA ot autochode and they will be able to get you the correct belts...
Old Jun 30, 2007 | 11:03 AM
NAIIZeater's Avatar
well finally got them on after testing out diffrent belt sizes. well i got them on Wednesday and they broke in pretty well in fact. thought at start up now it squeals. I'm gonna retighten this afternoon to see if it goes away. All in all the ud pulley feels great. Next is the straight pipe and headers. I'll keep ya'll updated.
Old Jul 4, 2007 | 11:02 AM
NAIIZeater's Avatar
alright, now the power steering wont stop suealing. any good remedies besides low fluid level? Or is there a particular power steering fluid i should use that is better then normal power steering fluid?
Old Jul 4, 2007 | 12:56 PM
Goofyz's Avatar
you will most likely need a new belt
new belt will most likely fix the problem do the twist test see if you can twist the belt more than 1/2 turn on its longest part between pulleys, if you can you probably need to do more tightening.
Old Jul 4, 2007 | 03:33 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
If it's squealing still, I'm willing to bet you OVERtightened it. Loosen it a bit.
goodoldZdays
FS: 300ZX (90-96)
Mar 12, 2009 10:36 AM
Phreakdout
Jul 16, 2006 12:22 PM
jooom
14
Feb 19, 2005 01:27 PM
OrangeZ32
Apr 9, 2004 03:21 PM
jbaran1123
Aug 21, 2002 05:01 PM
