Turn signal issues
Old Dec 3, 2009 | 05:53 AM
bnhunt's Avatar
Turn signal issues
New owner of a really nice 94 300zx NA. I have noticed some strange issues with the left turn signals though. When the car is just sitting they work fine. When brakes are applied they blink slightly faster. When the headlights are on, the signals blink very fast. I know this is usually a sign of a bulb out but as far as I can tell none are. This only happens on the left side, the right side works fine at all times. Anyone have any ideas? Should I just start by replacing all turn signal bulbs?
Also, the window washer fluid seems to have a leak somewhere. I filled it up and the next day the light was back on and it is empty again. I haven't had a chance to look for the leak, its pretty much been raining since I bought the car. Anyone have any advice of where to look, where leaks may be common?
Thanks!
Old Dec 3, 2009 | 08:09 AM
Welcome to ZDriver!
You might want to do a load test on your alternator. Is there any other electrical "weirdness" going on? If the alternator checks out, replace the flasher relay.
Old Dec 3, 2009 | 11:16 AM
bnhunt's Avatar
Thanks for the reply. I will have to check the alternator. Not sure exactly how but I will find out. No other electrical problems.
As for the washer fluid, I added some water to see if I could spot any leaks but I couldn't. I tried the washer fluid and it worked and was spraying blue washer fluid, so maybe the jug I added a couple days ago just had to work its way through the lines? The washer fluid light is out so we will see in a day or two if it stays that way.
Old Dec 4, 2009 | 09:45 AM
bnhunt's Avatar
Fixed the turn signal issue. Not quite sure how but I'll share incase it may help someone else in the future...
I took out all signal and marker bulbs, none looked burned out which makes sense because they all worked. So I took all the bulbs from the right side (the side working fine) and put them on the left side. Problem was solved. So one by one I swapped them back trying to use process of elimination to find the exact problem bulb. Ended up switching them all back and everything worked fine. Not sure if maybe there was some corrosion that came loose or maybe a loose connection that allowed the bulb to still work but was enough to throw off the relay.
Old Dec 7, 2009 | 08:09 AM
Outkast's Avatar
The sub harness tend to ware out and get loose connections at the connectors. You moving them may have temporarly snugged the connections back up.
plainwhiteZ
May 1, 2012 02:04 PM
gdcat51
Jun 27, 2009 12:15 AM
rookieszx
Jul 15, 2004 02:41 PM
OrangeZ32
Jun 19, 2004 03:35 PM
zcarron
Apr 12, 2004 11:24 AM
