Top Speed?
Old Dec 22, 2004 | 07:57 PM
  #51
bardabe's Avatar
Bad Speller
hmmmm Intresting thanx for the warning. how do I know what N, W, M, Z, P... whatever tire I got besides the size??? :doh:
Old Dec 22, 2004 | 08:00 PM
  #52
Rogue93TT's Avatar
UK speedo you say? OH, OH, OH send me one PLEASE.
Old Dec 22, 2004 | 10:27 PM
  #53
Copper727's Avatar
Gold Member
OooOoooo! I want one too! In fact, I think I want one of each!! :hpydance:
Old Dec 23, 2004 | 09:28 AM
  #54
91zxtt's Avatar
We generally see a tire size format as follows
255/40/ZR17. This is a Z series tire; which I believe is ratedsomething like 160+. If it is not directly in the size size coding of the tire, then you should be able to find it stamped on the sidewall. Or, ask the company that you bought it from.
I figure this little disclaimer should be added as well. Driving at these speeds is not safe, not matter which car you have, what tires are on it or how experienced you are behind the wheel, . You are putting yourself, your passenger, and anyone else on the road in jeopardy. The only safe place to do something like this is on the track. As someone said earlier, speed is like a drug.....please use it wisely.
Old Dec 23, 2004 | 10:44 AM
  #55
Riz Z Speed's Avatar
Administrative Brown Guy
the speedometer that copper showed is probably a Canadian model. I don't know of anywhere else in the world that uses MPH. I think everywhere else uses KPH.
Old Dec 23, 2004 | 11:23 AM
  #56
CanyonCarver's Avatar
Jack Of All Trades
I 2nd what 91 (sorry) said. I can go out from where I live and find a road where I can see for 10+ miles. No cars........ WFO. I've only gotten to 130 because my one out of balance tire starts shaking pretty bad at that speed. No shake at 80.
Anyway, read at the bottom of the following page about the Z rated tires.
http://www.tirerack.com/tires/tirete...eral/speed.jsp
There's no gaurantee that they'll hold up to 160+
Old Dec 23, 2004 | 01:17 PM
  #57
91zxtt's Avatar
I wasn't sure about that whole 160MPH thing. That's a good link. I know there are a lot of people out there who think a tire is a tire and that's about it. Facts show that's not the case. If you guys are going to make a speed run, make sure you have equipment that can handle it. It's one thing to get your car up to 130MPH. It's another thing to get it under control at that speed while the rear end and front end keep trading places.
Old Dec 23, 2004 | 04:46 PM
  #58
bardabe's Avatar
Bad Speller
YEAHH!!!!!!! Fairlady is fixed she is finaly done. I changed the 3 belts belt tensioner t-stat new waterpump gasket. she sounds so sweet but seems to idle @ like 1250 or 1150 rpm's... Normal or shouuld I do something? havent test drove her yet cause I need a new batter should I wait for a test drive??? :headspin: :chug: :dancing: :spot: :woohoo: :cheers: :cheers:
Old Dec 23, 2004 | 05:26 PM
  #59
91zxtt's Avatar
What did it idle at before? Nothing you worked on should've changed the idle. Check for vacuum leaks. Maybe you pulled a hose by mistake.
Old Dec 23, 2004 | 07:55 PM
  #60
bardabe's Avatar
Bad Speller
honestly U might think Im an idiot.... but I don;t remember so I'll just checkk all the vacum hoses. thanx what does yours Idle @ anyway?
Old Dec 23, 2004 | 08:14 PM
  #61
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
Normal idle is around 700 RPM.
Old Dec 24, 2004 | 02:46 AM
  #62
mtl's Avatar
mtl
We still use MPH in the UK also Aus still use MPH too
Old Dec 24, 2004 | 05:46 AM
  #63
DanZ32's Avatar
Dan's the Man
Rizz is correct, it is indeed Canadian.
Old Dec 24, 2004 | 08:42 AM
  #64
91zxtt's Avatar
Right now....it doesn't.
Dan's right. If you can get it down to 700-800RPM's, then you should be fine. Don't do it by adjusting the idle screw. That will just mask your problem. Here's a silly question, when it was idling at 1150, was the engine hot or cold? If it was cold, then you're fine. The RPM's will drop after about 5 minutes of run time.
Old Dec 24, 2004 | 04:53 PM
  #65
bardabe's Avatar
Bad Speller
ok yeah the engine was cold the RPMS droped to like 800. but now it seems to be leakign water from teh theremostat and check that out. yet the car seems to run hotter than before it runs like the 180 Spedo. is that normal or hotter than normal? well a little bet less just a little though, a little less than a quarter inch. where should the nedle be @ normal temperature. the t-stat it had before was stuck open. what Im goign to do is take the pipe off again and re clean it with a razor and put more silicone gasket. but it really help out for U guy's to tell me. oh yeah she haul alot stronger with those new belts no more squeaking!!!
Old Dec 24, 2004 | 06:35 PM
  #66
ZXDude90's Avatar
Do what now? The temp needle on mine is about in the middle, maybe a little below. Part of that I don't know what you're saying. Please try to slow down a little when you type.
Old Dec 25, 2004 | 12:54 PM
  #67
bardabe's Avatar
Bad Speller
UHHH? dudes I need a new battery what would be best besides the 139.99 dollar optima batteries???
:bling::bling::bling:
Old Dec 26, 2004 | 08:52 AM
  #68
Jack Of All Trades
$39.99 walmart............ You might get a "cool" battery for what you wanna spend, but it won't be much if any better.
Old Dec 26, 2004 | 04:13 PM
  #69
91zxtt's Avatar
Don't worry about a fancy battery yet. Get your coolant leaking problem fixed. It may not be your water pump that is leaking. There are 2 bypass hoses that could be leaking also. Did you remove both of those aluminum pipes? If not, then do it and check those hoses. They should be replaced, if you haven't done it already. You'll need the same gasket goop for those water pipes. Your car is running too hot. Mine runs just below half-way. Always has. At the temp that your talking about, the fan would run non-stop. You want to flush your system. Your radiator could have a clog in it also.
What coolant did you use? How much water did you add to the system? It should be distilled water. You should mix a 50/50 ratio of coolant/water.
Old Dec 26, 2004 | 06:50 PM
  #70
bardabe's Avatar
Bad Speller
ok the leaking problem is fixed. and as for the battery I'll go walmart like he said. as far as for the coolant I'm doing the system flush so I used it today witht that prestone cleaning thing with water. and tomorrow I'm adding that 50/50 coolant thing with the water. what ground kit should I go with? the Nismo E-bay one or the Stillen one???
here are the links:
Nismo Ground Stabilizer: http://cgi.ebay.com/ebaymotors/ws/eB...category=33577
Nismo Ground Wire Wires: http://cgi.ebay.com/ebaymotors/ws/eB...category=33574
Stillen Grounding kit: http://www.stillen.com/Sportscars_de...d=36689&page=1
What combination should I use or what single Item??? budjet 100$$ or I can wait for the money nesesary for the parts. oh and all my interior components are dead (clock, stereo, and lights. [exept for the one by the cigarete lighter and the dash] everithing else works) im going to get that checked out next week. I don;t do Electric . I'm going to take to get the transmition flushed and refilled. how many bottles of that redline oil should I use? I'm going to do the gear oil too along with the diferential. I mean Y not? how many bottles and what oil to use???
Old Dec 26, 2004 | 08:17 PM
  #71
entropy31's Avatar
The Cake Is A Lie!
for the electrical, check all your fuses before you take it anywhere. thats probably the problem, and fuses are cheap. unless you have to get a $15 dealer only friggin fuse link
Old Dec 26, 2004 | 09:22 PM
  #72
bardabe's Avatar
Bad Speller
yeah ima do that this wheek with time and everithing .... what about the Upgrades???
Old Dec 27, 2004 | 11:08 AM
  #73
91zxtt's Avatar
Tranny info....
http://www.ttzd.com/tech/fluidchangetech.html
Grounding net....make your own.
http://www.ttzd.com/tech/groundnettech.html
Don't waste your $ on the ground stabilizer. Not necessary. Just another gimic.
Your lighting problem is likely a fuse. The fuse panel is located down by the dead pedal.
Spend some time on Rizz's sig page. Much of what I have learned about the Z is from reading through the links he has on there.
Old Dec 27, 2004 | 11:44 AM
  #74
bardabe's Avatar
Bad Speller
:doh: :doh: :doh: ok Im not even gonna mess with the fuses because my car keeps killing my batteries, this is the 3rd time. what to do? I'm thinking of taking it to an electrician to get it checked out. it's probably a short. but I hae no Idea where. so what's the most convenient thing to do???
Old Dec 27, 2004 | 11:57 AM
  #75
91zxtt's Avatar
It's probably not you're battery. It soundsl ike you have a voltage draw; i.e. a short somewhere. Were you able to find a burned out fuse? If so, then that will narrow down your search. What stereo do you have (OEM or aftermarket)? Who installed it? Check the wires behind the head unit. It's pretty cramped back there, so it's easy to pinch a wire and cause a short.
