Throtle Body help! PLZ!!
Old Nov 24, 2011 | 04:08 PM
Mangrum1184's Avatar
Well I have A 90 Z32 Automatic. Today I noticed the car running a lil rough so I used throttle body cleaner and Cleaned it out. And Now it wont start or Idle. It just dies out. But when I take the Right Intake back off and pour More Cleaner in, It Fires back and then dies. Whats the Issue?
Old Nov 24, 2011 | 09:49 PM
lowkeyz's Avatar
you had another thread about hard starting under 45 degrees?...did you fix that problem or were trying to and this started happening?
Old Nov 25, 2011 | 08:34 AM
Yes I had the 45 Degrees. I Fixed that and Now it wont start . It just keeps Cranking and Cranking and Never starts now. Its weird now I cant even start it anymore. Every time I Spray Thole cleaner in the Bodies. It helps it attempt to crank but never does.
Old Nov 25, 2011 | 03:13 PM
Check the plug on the CAS.
Old Nov 25, 2011 | 04:33 PM
napoleonzheking's Avatar
F5 Hero
Sounds like fuel.. If you're spraying some sort of combustable anything in there and it tries to start, then it isn't getting fuel.. Check your Injector connectors. Replaced your fuel filter recently?
Remember a car needs three things to run, air, fuel, and spark...
Old Nov 27, 2011 | 04:04 PM
I LOVE YOU GUYS!!! Haha Y'all Are super Awesome! Will do!
pcaudell
Oct 2, 2009 07:35 AM
EatmyDust
Apr 11, 2006 09:04 PM
mattduskater
Feb 8, 2005 09:40 AM
rifleman502
Nov 6, 2004 02:26 PM
