Simple Question: Big Help! Where is the idle screw?
Old May 16, 2007 | 03:13 PM
jgz's Avatar
jgz
I know this is going to be a gravy question for any Z lover, but I am having trouple tracking it down. Some guidance would be greatly appreciated!
I have a 1991 300zx N/A 5sp, and I cannot for the life of me locate the idle adjustment screw. I know it is attached to the IAA and the air regulator, but.....
An idiots guide to locating it inside of the engine bay would save me a trip to the dealership and help a fellow Z fan out in the process.
Thanks in advance.
Old May 16, 2007 | 09:19 PM
ezramoore's Avatar
From: Port Townsend (Home) and Bellingham (School), WA
Check Riz's Link page for the FSM or a tech article next time. You can find the link in his signature or as a sticky in the Z32 forum.
Here is a link, look at picture 2. The idle adjustment screw is on the IAA, make sure to disconnect the connection to the air control first. Its all on the page below.
http://home.swipnet.se/e-solutions/IdleTech.html
Old May 17, 2007 | 09:30 AM
b300z's Avatar
caught the z fever
if you have a high, or unstable idle, DO NOT just go and adjust your idle screw.
do a search if youre having idle problems
Old May 17, 2007 | 05:11 PM
jgz's Avatar
jgz
Hay,
I appreciate the responses, but I am having a time physically locating the IAA inside of the engine bay. I know what I am looking for, as I have already looked at the link posted.
The idle is low-->around 600rpm, which I believe is causing it to stall, when I brake to a stop. I am trying to figure out what is the underlying problem of my stalling/idling issues. I have already checked a ton of links dedicated to this issue, and I am working on this idle issue right now.
There is about a million and one things that could be causing it; it seems like anyway. I would like to solve it myself before I get taken to the cleaners at a Dealership.
Old May 17, 2007 | 10:32 PM
b300z's Avatar
caught the z fever
Originally Posted by jgz
Hay,
then i would still not reccomed you adjust the idle screw just yet. disconnect the AAC and see where the idle goes to...and check the list at where it should be
NA AT = 720 RPM
NA MT => 650 RPM
TT => 700 RPM
the IACV is on the drivers side at the very back corner of the engine. id suggest taking that and the air regulator off and clean and ohm test them. good luck
Old May 18, 2007 | 05:42 PM
jgz's Avatar
jgz
Thanks for the feedback, its greatly appreciated. Its on the books for Sunday, I will give a break down of how it goes. Wish me luck!
Old May 18, 2007 | 05:59 PM
entropy31's Avatar
The Cake Is A Lie!
you should NEVER have to touch the idle screw on a z32. all you will be doing is masking the real problem.
Old May 18, 2007 | 09:49 PM
b300z's Avatar
caught the z fever
i think i already said that twice
bcat6976
Apr 27, 2015 11:25 AM
emo236
26
Dec 2, 2011 12:54 PM
83Zturbo
Jul 8, 2009 07:26 AM
zguru
Nov 27, 2002 08:30 AM
