Short circuit or Electrical problem unfixable???
#26
On that kill switch, there are 2 wires that exit to the right of the car and there are 2 wires that wrap aournd the back of the fusebox and disappear. Where do those two wires go? You should just be able to cut those 4 wires and eliminte the kill switch. The car won't know it's gone unless it runs to an alarm; which could cause a problem.
You would have to splice in all of the wires at the fuse box by the battery. Can you see the wires under that fuse box? Do they look fried?
#27
yeah I can see the wires but they don't look fried. don't know about inside tho. but no the ones outside don't look fried. I was thinking of soldering the wires instead of splicing. what's best??? i'm also taking in consideration of replacing the Battery cables with the ones from concept z performance look:
http://www.conceptzperformance.com/C...244.11.178.221
has anyone done this before? is it a hard job? any cuttingor splcing? or is it how it says jut plug and conect???
#28
It could help, but I don't think that's your main problem. There are 2 grounding points...1 is on the firewall; which is easy to get to. The other is at the top of the bell housing; which isn't as easy to get to, but is much easier in an N/A, and is very doable. It's probably worth a shot. I'd look at making that grounding net also.
I personally feel that soldering makes a much better connection than using butt connectors.
#30
With the car youre looking at on ebay i would say take a look at it before you buy it if possible. and NEVER sign i mean NEVER sign an AS-IS until you've checked the car out driven it for a lil. I'm just giving you a little warning because i got f*cked over ROYALLY with a damn AS-IS. :doh: Just be very careful when ur buying a car on ebay.
#31
yup I was the one giving u advise on your TTconvertion member? you got your car with a bra and holes on your bumper. bummer dude. but yah I'll go test drive it befor I buy it. I'm taking my tools to check compretion ratioand that ECu tuningthing soI can see if there is any codes going off on teh ECU.
#34
I actually made a large purchase from Z1 recentley, i bought the entire IC pipe set for an amazing price and they shipped it to me when they said they would and i had not one problem with them. Now AMZ Performance on the other hand i'm still having trouble with (donno whats going on with that) but i didnt have any problems with Z1. :headspin:
#37
well I can;t seem to get someone on the phone to order my fusible link box. I think i might have to call early in themorning. what's a good time to call. I call @ 3:00pm and they are clsoed.
#46
Originally Posted by CanyonCarver
Something close to "Dag Nabbit" I think.
#50
Originally Posted by bardabe
o kno fork nagget.U should have seen the dates in my school papers today/ I kept on putting 04 instead of 05.
