Ruff idle,cuts off,back fires plz help
Old Jan 3, 2010 | 07:54 AM
davedsz's Avatar
My problem started 9 months ago, I noticed that my car had a hard time to when it was cold outside. Once car was warm it ran fine. I found out the ignition module was bad, I changed that, and then the car ran fine, the next thing i noticed a strong gas smell in the car and i started to get hesitation and stall outs. I found out that the fuel pressure regulators were linking bad. I changed them and put after market adjustable regulators on, the hesitation and stall outs got worse. My mechanic noticed that my engine harness was worn out, so I just replaced it the other day after spending 13hrs installing the new harness I tried starting the car and it struggled. Once started i had to keep my foot on the gas pedal to keep it running. I unplugged the mass air flow sensor and the car started right up, but as soon as I plugged the sensor back up the car cut off. So I thought the sensor was bad right, I go buy a new sensor and install it last night and start it up I got the same problem. Unplug it and the car starts right up. I did notice I have a vacuum leak on one of my hoses. I need some help trying to figure out why my baby wont run right
Old Jan 3, 2010 | 06:43 PM
KasbeKZ's Avatar
Pr0n Addict
don't you think you might want to fix that vacuum leak before you look any farther? vacuum leaks do cause problems...
Old Jan 6, 2010 | 08:55 AM
davedsz's Avatar
vaccum leak fixed
When we put the wiring harness back in we forgot to clamp 1 vacuum hose, but car is still doing the same stuff. do you have any ideas what it could b that i can check out
mossyoak.1988
Jan 14, 2012 07:07 AM
KasbeKZ
Nov 9, 2009 05:30 PM
2.8.0.Z.X
Jan 13, 2008 05:22 PM
Late Apex
Apr 27, 2006 04:59 PM
