pics and questions
Old Mar 14, 2008 | 10:33 PM
  #26
KasbeKZ's Avatar
Pr0n Addict
but is it not more expensive to get the one piece then to get the 2 piece and the carrier? last i looked, the OEM shaft was in the 300's or something.
and thanks for the clarrification. but isn't that the one that connects to the hose that meets the middle of the balance tube? that's the one i cleaned with wd-40 i thought... or was that something else?
Old Mar 15, 2008 | 12:38 AM
  #27
ZLover4Life's Avatar
Encyclopedic Knowledge
I'd have to see a pic, but with how you described it, it sounds like the IACV.
And how many people actually have to replace the entire drive shaft? Nobody I know. Normally it's sufficient to replace the center support bearing (a.k.a. carrier bearing), which is $125.
Old Mar 15, 2008 | 09:02 AM
  #28
b300z's Avatar
caught the z fever
i believe you are talking about the air regulator, which is connected to the IACV, which is on the back drivers side of the plenum.
Old Mar 15, 2008 | 12:56 PM
  #29
KasbeKZ's Avatar
Pr0n Addict
the one that i have to wack is one that has a connector that points toward the right side of the car and it is located on the drivers side of the back of the plenum. it's kinda long. the other one, on the top, seems to be working, because i can do the pinch test without having an effect on the idle
the best mechanic at the closest Z shop told me after i replace my carrier bearing that failures in those bearings was almost always due to a bad U-joint. the extra stress from the flat spot in the u-joint causes the bushing to break. quite often at least. not to say that the carrier bearing couldn't go out on it's own, but since i replaced mine, and now i have a shake coming back, i stronly advise anyone with a bad carrier to get a one piece instead. if you can check all of your u-joints and prove them to move perfectly well, then maybe just the carrier is sufficient.
Old Mar 25, 2008 | 05:51 PM
  #30
KasbeKZ's Avatar
Pr0n Addict
here is a pretty simple question:
my drivers side door clicks or knocks when i close it, and the passenger door is perfect. i had the problem in my honda and just replaced the bolt that the door swung on. the hinge i guess you'd call it. but that door, you could lift up and down. the z door won't move any, so i think it may be a problem on the part of the latch on the body. what usually causes this? i know its happened to plenty of high mileage z's!
Old Apr 10, 2008 | 08:28 PM
  #31
KasbeKZ's Avatar
Pr0n Addict
ok here's another bit of a question. a bit more difficult...
i'm pretty sure that this is the throw-out bearing. when the car is at all cold, or not driven for a few minutes, there is a terrible loud grinding sound and a bit of a scraping feel from the clutch pedel when the clutch goes in. it goes away after a bit of careful driving, and everything still works fine. i'm just being REALLY careful and easy with it.
it's getting worse and worse, so i think i'm ordering a bearing tomarow and changing it next saterday. anything else that could cause this? not a pressure plate i hope...
BTW, while i'm in there, can anyone give me a mm measurement on the clutch disc? i want to see how very old it is. it feels perfect to me, so i'm hoping to leave it for a while. but if it is too worn down, i guess i'll have to go ahead and do it.
if **** keeps going wrong i'll never be able to afford to fix the brakes!!!!
Old Apr 11, 2008 | 06:43 AM
  #32
b300z's Avatar
caught the z fever
should be the throw out bearing. if you do pull the tranny, get new fluid, rear main seal and tranny seal. honestly, id also get a new clutch and resurface the flywheel, just so you wouldnt have to drop the tranny again. but that depends on how those two parts look.
btw, if you havent thrown it away yet, try selling your carrier bearing before you decide to throw it away. theres plenty of people who will buy it
Old Apr 11, 2008 | 12:58 PM
  #33
KasbeKZ's Avatar
Pr0n Addict
i didn't go over to the one piece and my old carrier was totally shredded. it came off in 2 pieces.
but thanks for the advise. which tranny seal would be the one that you are reffering to? it does leak a bit.
Old Apr 13, 2008 | 03:47 PM
  #34
KasbeKZ's Avatar
Pr0n Addict
well i ordered the throw out bearing today. $44. i hope there isn't anything else wrong. or that nothing else goes wrong in the next week of driving!
Old Apr 14, 2008 | 04:57 PM
  #35
KasbeKZ's Avatar
Pr0n Addict
i got my new IAA from hoov and put it on. no change. it doesn't rev quite as high at start up as it used to, but warm idle is still about 1100. air regulator next? i just don't know. i was really counting on that fixing it. only about 2 more things that i know of to try. and at $60 a piece, i'm not putting new o2 sensors on it for the last few months of ownership
Old Apr 14, 2008 | 05:37 PM
  #36
b300z's Avatar
caught the z fever
check the resistance on the iacv and the aru
Old Apr 14, 2008 | 05:40 PM
  #37
b300z's Avatar
caught the z fever
and the gasket under the cover inside the bellhousing...i forget what that piece is called
well, just do the rear tranny seal as well
Old Apr 14, 2008 | 07:38 PM
  #38
KasbeKZ's Avatar
Pr0n Addict
i guess i'll see it when i get in there. thanks for the advise. i'll check those things next
Old May 27, 2008 | 04:44 PM
  #39
KasbeKZ's Avatar
Pr0n Addict
well, sadly, i'm thinking i may have to be selling the Z. with gas the way it is, and parts as high as they are for the car, i don't think it's my best choice to go through college with. so, expect to see a for sale thread for it in a few weeks.
but for now, how about some help with the price?
so, i have $9000 total in the car. i bought it for 4, and put 5 more into it. it is almost mechanically perfect. rebuilt heads, new valves, new OEM injectors, pcv valves, timing belt, tentioner, middle idler, drive belts, carrier bearing, gear oils changes, all new tires, new PTU, short shifter, new paint (on body and wheels), and much much more.
basically, the condition is... a few dents, interior is not fully attatched because i... 1. don't care and 2. can't figure it out (meaning the panels in the back and a few other small things). a few small paint chips, slow T-top leak, some others.
tinted glass, ricer exhaust.
162,XXX miles on the car, not the heads. it holds oil pressure, doesn't leak, and just drives great. completely reliable for about 4 months strait now.
i'm hoping for $6K.... crazy?
Old May 27, 2008 | 04:55 PM
  #40
6k is doable if you finish the interior and try doing a detail job on the paint and stop the leak thats all easy stuff.
Old May 27, 2008 | 05:07 PM
  #41
KasbeKZ's Avatar
Pr0n Addict
yea those are some pretty big things. how do you fix T-top leaks? i know where it is, or the general vicinity, but what do i put on it?
Old May 27, 2008 | 05:08 PM
  #42
new stripping probably. lol.
Old May 27, 2008 | 05:10 PM
  #43
KasbeKZ's Avatar
Pr0n Addict
last i saw, T-top seals were around $500 a side
Old May 27, 2008 | 05:15 PM
  #44
ummmm... definitely not, you get a tard reward for the day because of that. lol.
http://www.thezstore.com/page/TZS/CTGY/SWR04F
500 is the cost of an entire body seal kit MAYBE cause i know its about 300 for all the new weather seals in an S30.
Old May 27, 2008 | 05:29 PM
  #45
KasbeKZ's Avatar
Pr0n Addict
wow. i'll take that award proudly now! well that's good news. thanks. but on that one, i'd rather just sell it on a sunny day, if you know what i mean...
Old May 27, 2008 | 07:16 PM
  #46
yeah thats what i did. lol. then after i sold it sooooo much more went wrong with it other than a bum cylinder and the tiny tiny leak in the t-top. but yeah i still got 5k for it. i needed that car gone so i disguised a few problems but a few more showed up on him that i was surprised about but w/e
Old May 28, 2008 | 06:35 PM
  #47
KasbeKZ's Avatar
Pr0n Addict
any other advise on a price? any interest even? i just want to see if this is a rediculous price and that i need to change my plans. but when i was looking for a car, i considered myself very lucky to find a good driving one for 4K.
Old Jul 29, 2008 | 05:00 PM
  #48
KasbeKZ's Avatar
Pr0n Addict
what happened to my pics on this thread? anyway, just for closure, i'm going to mention that i am keeping the car, and painting it white. i have 4 years to get it ready for a turbo swap. i will do the suspension, the interior, and the paint, and take the spoiler off.
greyfox
May 31, 2007 08:29 AM
Edz280zx
May 20, 2007 10:31 AM
bigjim240z
16
Jan 26, 2007 09:15 AM
RodMoyes
Apr 21, 2006 12:08 PM
280zExTURBO
Oct 20, 2005 06:51 PM
