Oil pressure
Old Mar 3, 2004 | 08:20 AM
91zxtt's Avatar
Oil pressure
Just looking for a general survey on oil pressures. How much oil pressure do you have at varying RPM's and temperatures. These figures will vary based on types of oil. I'm using 15/50 Mobil 1 syn. I'm running a bit over 100PSI when cold. When the engine is hot, I'm running 20-30 PSI at idle, which climbs to about 60PSI at or near 2500. The pressure climbs to 75 or so near redline. Let me know what you have. I also have a larger capacity oil cooler from Z1 and I'm using a K&N oil filter. I'm not using any oil additives.
Old Mar 3, 2004 | 11:54 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Did you install that new oil pressure gauge when you did the oil cooler?
Old Mar 3, 2004 | 03:42 PM
91zxtt's Avatar
Um, no, why?
Old Mar 4, 2004 | 02:33 PM
emo236's Avatar
confuzed member
Mine's just about where yours is.
Old Mar 4, 2004 | 02:37 PM
I'm just wondering where you got such precise numbers or were you just guesstamating?
Old Mar 4, 2004 | 03:36 PM
91zxtt's Avatar
I'm just that good. Nah, I was just guesstimating. I figure you've got marks at 30/60/90/120 on the factory gauge, so you can get pretty close after that.
Old Mar 4, 2004 | 08:13 PM
emo236's Avatar
confuzed member
Is you notice in his first post, he labeled everything along with an "about" or "or so" or labeled it as "20-30 psi." But, why do you ask, I'm just curious.
Old Mar 5, 2004 | 08:18 AM
91zxtt's Avatar
He was probably bored, or decided to try my selective reading.
Old Mar 5, 2004 | 09:22 AM
emo236's Avatar
confuzed member
selective reading was what I was thinking.
Old Mar 5, 2004 | 10:44 AM
Actually I had noticed that you stated that you had just installed the larger oil cooler and I remembered that someone had asked me about where to place a sensor for an oil cooler. I didn't remember if it was for oil pressure or oil temperature. I thought that might have been you is all.
Old Mar 5, 2004 | 11:00 AM
emo236's Avatar
confuzed member
At first I thought maybe you were implying that he might be getting an incorrect reading b/c of the larger oil cooler.
greenemerald300
Aug 30, 2010 03:23 PM
FubarI33t
Apr 27, 2010 08:45 PM
FubarI33t
Dec 12, 2009 10:03 AM
tonsoffun300zx
Sep 21, 2009 10:51 AM
y2daniel1981
Oct 25, 2006 10:24 AM
