Oil pressure
Oil pressure
Just looking for a general survey on oil pressures. How much oil pressure do you have at varying RPM's and temperatures. These figures will vary based on types of oil. I'm using 15/50 Mobil 1 syn. I'm running a bit over 100PSI when cold. When the engine is hot, I'm running 20-30 PSI at idle, which climbs to about 60PSI at or near 2500. The pressure climbs to 75 or so near redline. Let me know what you have. I also have a larger capacity oil cooler from Z1 and I'm using a K&N oil filter. I'm not using any oil additives.
Actually I had noticed that you stated that you had just installed the larger oil cooler and I remembered that someone had asked me about where to place a sensor for an oil cooler. I didn't remember if it was for oil pressure or oil temperature. I thought that might have been you is all.
Nah, I was just guesstimating. I figure you've got marks at 30/60/90/120 on the factory gauge, so you can get pretty close after that.
