Maf
Old Oct 12, 2010 | 04:39 AM
Sam's Avatar
Sam
Maf
hello, okay so i went to this shop after plenty of searching at parts stores and i found this MAF at last.. paid for it 80$ (used) and turned out to be an n60 MAF (no refund).. so i am pretty sure there are no n62 MAFS out there and i just wanted to ask if i can use this n60 maxima maf ?
2nd question: i heard somewhere that this maf reaches its limit at 350whp.. and my car is a stage 3 now.. so its at the limit.. now suppose i went with selin dual intake and i bought another n60 maf will it max out or the max hp would be divided between the 2 mafs ?
thanks
Old Oct 18, 2010 | 12:02 AM
Selin Design's Avatar
Sam,
Unfortunately you can't run N60 MAF sensors with the translator. You should return the N60 and try to find an N62 unit from another source. I know that SpecialtyZ has some on hand that are in known good condition. If not, try asking around the forums. Good luck!
Old Oct 19, 2010 | 02:14 PM
Mrmoose's Avatar
Hmmm good question about the splitting up the max hp between the two, I would also like to know this!
