import tuner
Guest
Posts: n/a
import tuner
I just read the december import tuner and I am so glad to see a z32 on the cover. After reading the article I was kind of disapointed I mean 500+ horses and all it could run was a 12.98 ET. I was just wandering if that is what I should expect of my z (when I get it). I was also wondering if there is a ball bearing twin turbo set up for a z32 that can take about 900HP or will I have to change to a single turbo set up. Also how much HP. can the stock crank take.
Guest
Posts: n/a
Re: import tuner
It was Sport Compact Car. Like he said in the article, the Z isn't made for 1/4 mile it's a high speed car. It said the problem with the time was the lighweight clutch and flywheel. Those aren't meant for drag.
'91 300ZX NA 2+2
'89 240SX Coupe
'91 300ZX NA 2+2
'89 240SX Coupe
Guest
Posts: n/a
Re: import tuner
just keep in mind that these are not drag strip cars.....
My car doesn't put down good times at the track but on the road there is not much that has been able to mess with it & that is really good for what little that is done to it! If you're out to impress everyone with numbers you might wanna find a mustang, camaro, eclipse, etc.. but if you're more into personal satisfaction, these are the right cars for ya! I luf mines!
DDonovan
Canada
23
Sep 3, 2013 10:13 PM
creativefilmcar
Aug 31, 2007 05:07 PM
