ignition coil resistance. wtf is "approximately"
Old Oct 31, 2011 | 03:47 PM
Zombie's Avatar
This I believe is my first post on here but I've been creeping around for a while now. Anyways, I have a 90 tt that popped a head gasket this time last year. Heads and turbos were rebuilt, reassembled myself and put in, and now I'm not getting spark. I've checked everything I know how to. Voltage from the harness to the coil pack is good, continuity between ptu and coil pack harness is there. I don't know how to check the ptu to see if its good, it is the new style. My question is, I checked the resistance on the ignition coils, and according to the fsm its supposed to be "approximately" .7 ohms. So wtf does approximately mean? If i get a sporadic reading between 1.4 and .9 is that good? What is my tolerance for checking these things is what I'm asking. And, I'm gonna be picking up a logic probe tomorrow to test the pulse from the ptu according to the fsm. Is there anything else I need to check now? It's much appreciated guys.
Old Oct 31, 2011 | 04:11 PM
rogerz's Avatar
Grumpy & Helpful
coils have low ohms by nature. if you don't get an open (ie infinite ohms) it is probably good. not a critical value. pull it and the plug hit it with 12 volts and see if you get spark.
Old Oct 31, 2011 | 04:32 PM
Check continuity of the CAS harness and pull the CAS to see if the injectors click when you spin it.
Old Oct 31, 2011 | 04:52 PM
Zombie's Avatar
Ok well of the "approximately" means anywhere close than the coil packs are good. I'll check the CAS when I get up tomorrow (night shift worker) gonna pick up some connector cleaner too and make sure everything has a good contact. Should I grab a logic probe and go ahead and check the pulse signal from the ptu?
Old Oct 31, 2011 | 05:17 PM
Zombie's Avatar
Old Nov 1, 2011 | 11:30 AM
Zombie's Avatar
CAS is good. Pulled it and spun it and the injectors clicked. Didn't bother checking the voltage. So the only things I haven't checked is ecu signal to the ptu, and the ptu itself.
Old Nov 10, 2011 | 12:52 PM
Zombie's Avatar
Ptu was bad. Also had a busted intake pipe.
TheShanMan
Mar 8, 2014 03:25 PM
bataradena
Aug 7, 2012 01:55 PM
Lev
Sep 19, 2009 12:35 PM
PowerhungryBill
Sep 16, 2008 09:04 AM
runningjalapeno
Oct 4, 2006 01:02 PM
