help radiator leaking...
Old Mar 12, 2005 | 04:20 PM
FaYeZ_90NA's Avatar
wassup guys. i just got my trans replaced witha jdm 1. its an automatic. after a couple of days of driving i hv noticed that coolant leaks from my under my car. it happens only the car is parked but stops within 1 or 2 mins. i hvnt taken it to my mechanic yet but i hope u guys can give me a head start on this matter. since i am a new z owner, i was wondering how much the rads go for with install. will an aftermarket 1 cost me less? if so... which would be a good choice. thanx ya all in advance for ur help. -the poor z owner .
Old Mar 12, 2005 | 05:38 PM
CanyonCarver's Avatar
Jack Of All Trades
Are you sure it's leaking from the radiator? Have you checked all of the hose connections? Is your overflow tank over fiilled? These might be some things to check first.
Old Mar 13, 2005 | 12:27 AM
Ineedthespeed's Avatar
heater hose
make sure you check the heater hoses behind the intake they are right above the transmission. if this problem occured after the tranny replacement it could have to do with the heater hoses. just check it out
Old Mar 13, 2005 | 03:10 PM
FaYeZ_90NA's Avatar
i hv noticed that the coolant doesnt drip from under the radiator but a little further down(btw engine n belts), so hopefully its 1 of those hoses. i hv an appointment with my mechanic tomorrow for a exhaust change. he should be able to pin point the problem for me and fix it. thnx a lot for the advice. i hv a gut feeling it has to do w/ 1 of the heater hoses as speed suggested. i'll check em out n let u guys know. thnx for all ur help.
Old Mar 13, 2005 | 09:23 PM
91zxtt's Avatar
I bet there's a small leak in either the upper or lower radiator hose and it's running down the hose and dripping from the lowest spot on the car. Tighten all of your clamps and see if it stops. If it's not that, then it sounds like it's in the same vicinity as the water pump.
Old Mar 13, 2005 | 09:56 PM
FaYeZ_90NA's Avatar
hey 91 what do ya mean by 'water pump vicinity' that it could be the water pump itself? dude dont tell me that i hv to change the water pump now. wuuhuu....
Old Mar 14, 2005 | 05:32 AM
FaYeZ_90NA's Avatar
ooops i meant buuhuu!!
Old Mar 14, 2005 | 08:41 PM
91zxtt's Avatar
Yes, that's what I meant.
Old Mar 14, 2005 | 09:29 PM
Zgringo's Avatar
El Viejo
Hey FaYeZ 90NA, you asked and got some great answers. Now bite your lip, cross your fingers, say your prayers tonight and hope it's a clamp, and not a water pump.
Old Mar 17, 2005 | 10:28 AM
FaYeZ_90NA's Avatar
it was the pump. so i just got the whole 120k done. my odo was reading 100700. so my car is fixed but i am broke! thnx a lot for ur help guys.
datsuns130
May 9, 2012 09:41 AM
81-280zxnt
Sep 25, 2009 09:48 AM
droc217
Feb 5, 2005 07:53 PM
86ZXTurbo
May 28, 2003 03:15 PM
ADukesIII
May 15, 2003 09:25 AM
