Fuel Pump Questions
Old 03-11-2006, 11:28 AM
Z'sOwnTheRoad's Avatar
Fuel Pump Questions
Im wondering if anoyone knows a link to a good faq or post on how to test a fuel pump and how to adjust it?
Z'sOwnTheRoad is offline
Old 03-11-2006, 05:40 PM
japanz's Avatar
Being an electronic fuel pump you will know if it is not working. You should be able to hear it prime when you first turn the ignition. No prime, no gas, no go. A large paperweight.
japanz is offline
Old 03-11-2006, 07:23 PM
jfairladyz's Avatar
You can check voltage at the pump with a voltmeter. If you've got voltage and the pump aint working then you do indeed have a paper weight. If you have no voltage then the problem most likely lies elsewhere in the circuitry.
jfairladyz is offline
sameerb1
03-20-2011 05:21 AM
mrprofile
06-25-2010 11:23 PM
dapper189
03-18-2008 09:15 AM
ern
10-20-2006 07:01 AM
280ZXtreme
04-10-2001 07:00 AM
Quick Reply: Fuel Pump Questions
