Fuel pump fuse?
Old Apr 10, 2006 | 10:10 AM
nismo613's Avatar
Fuel pump fuse?
I was wondering where the fuel pump fuse would be, or whether or not it is located in the module for the fuel pump relay. The car started fine yesterday, and started this morning for a few seconds and then died. Now it will not start at all. It sounds like a fuel issue, so I went to see if a fuse blew for the fuel pump but could not locate it. I located the relay under the kick panel, and it does indeed click when the ignition is turned on. I'd rather not have to replace the fuel pump, I am hoping that it is something as small as a fuse. Any help as to where it is located or anything else would be appreciated. I hope it's not the pump itself.
Old Apr 10, 2006 | 05:24 PM
napoleonzheking's Avatar
F5 Hero
have you determined it is even fuel?? unplug the main fuel line infront of your fuel filter, point it at the ground, have a friend turn the key on then off super fast, that should turnthe fuel pump on for a second, see if fuel comes out, if not, then yes, it is a fuel pump issue.
sameerb1
Mar 20, 2011 05:21 AM
derekinthez
Jul 21, 2007 01:53 PM
ern
Oct 20, 2006 07:01 AM
chrischicoine18
May 25, 2006 11:46 AM
280ZXtreme
Apr 10, 2001 07:00 AM
