Engine pull advice
Old Jan 3, 2014 | 08:47 PM
Dcap70's Avatar
Engine pull advice
Hey everyone. I've got a 1990 twin turbo and I'm currently in the process of pulling the engine. What a pain in the butt! I've finally got everything undone and ready to come out. I was wondering if it'd be easier to pull the engine and trans together or if I should do it separately? It's a 5 speed if that makes a difference. Thanks for the help!
Old Jan 3, 2014 | 10:22 PM
Rupe's Avatar
Horsepower Mathematician
https://www.zdriver.com/forums/300zx...ling-na-38946/ boom
Old Jan 4, 2014 | 10:21 AM
KSpakes87's Avatar
Pull them together.
Old Jan 4, 2014 | 08:07 PM
vuez32's Avatar
Pull them separate, it'll be faster and less of a pain. It's almost impossible to try and angle the motor and trans out together from the top. If you want them out as one unit you'll have to drop it from below by removing the power steering rack.
Old Jan 4, 2014 | 08:30 PM
KSpakes87's Avatar
Have you ever pulled one? In the z32 unless you have a gigantic extension and air tools or a steady hand to hold the socket in place on the upper bell housing bolts you can't separate in the vehicle. Most likely you will just round off the upper bolts trying to break them loose.
Also I have never once in my many pulls on these motors had an issue pulling BOTH from the top. That's the easiest way to do it. It's makes it a whole lot easier to disconnect and reassemble out of the vehicle on top of that.
I can pull both from the top with no air tools in less than 2 hours.
Pulling them separate makes no sense at all.
Old Jan 4, 2014 | 11:02 PM
vuez32's Avatar
when I pulled my motor and trans for a TT swap it difficult to pull from the top. Even with the radiator and fans out there was no room for the bottom to guide the trans out. Unless you had a lift that allowed enough room for the trans to clear from the bottom. Most of us are doing this in a garage with about 1foot and half of lift with jack stands. I did not require the use of air tools to take out the bell housing, maybe it was just my luck. However if your way is better please explain it to the rest of us so we can save time. So far I've pulled two motors and three trans out of z32's so it just from my experience.
Old Jan 5, 2014 | 06:23 AM
KSpakes87's Avatar
I have done this pull 6 times in the Z32 and once in a J30 in the grass or dirt. I have never heard anyone besides you suggest to pull them separate.
I too do this on the ground with jack stands and an engine hoist. There is no secret, you have to angle the motor up and transmission down and I do this with an engine hoist and a strap around the plenum. Never once has anything got in the way.
Same thing for putting back in. Same angle and then when tranny has cleared firewall you put a floor jack under it to slowly level the the angle as you slide it in.
So much more simple than supporting the tranny under the car and trying to separate while laying on your back. Then trying to spline back up in the same position.
Old Jan 5, 2014 | 06:29 AM
KSpakes87's Avatar
https://www.zdriver.com/forums/300zx...tt-swap-34511/
Here is my write up on my TT swap I did and you can see the conditions I pulled my motor in. Also see the motor and tranny still connected during the swap.
Old Jan 5, 2014 | 12:51 PM
vuez32's Avatar
I'll have to try it out next time I need to do a pull.
Old Jan 5, 2014 | 01:07 PM
KSpakes87's Avatar
A big plus to pulling them together is you don't need any help from somebody else unless you just like the company.
Old Jan 6, 2014 | 07:56 PM
vuez32's Avatar
Have someone around to talk to is always fun, even if they are just hand out tools.
Dcap70
Jan 3, 2014 08:53 PM
jaredjmoore89
51
Aug 29, 2008 02:40 PM
justinmy300z
15
Oct 15, 2006 06:28 AM
theramz
Aug 12, 2003 08:38 PM
wickedshadowz
Jul 28, 2002 09:19 AM
