Could it be a clutch problem?
Old Sep 12, 2005 | 06:59 PM
MarkieMark's Avatar
And the Funky Bunch...wtf?
*I posted this on 300ZXclub.com but it's kind of slow there.
I've only had the z for about a month. I started to notice some problems when driving it. One problem is when at a stop light sometimes i press the clutch and put it into 1st gear. When the light turns green sometimes the clutch is really stiff coming up. But once you start driving again it goes back to a normal feel. The previous owner put an aftermarket clutch but i'm not sure what kind. Could the problem be that it wasn't bled properly? It doesn't really bother me but i just want to know what's going on.
Old Sep 12, 2005 | 09:48 PM
Riz Z Speed's Avatar
Administrative Brown Guy
bleed the clutch if need be. There's two bleed points, do a search, i've posted it a couple of times.
On my Link Page there's a link to an splparts.com writeup on clutch adjustment.
Old Sep 12, 2005 | 10:02 PM
emo236's Avatar
confuzed member
sprung release? Also, it could be your master cylinder going.
Old Sep 13, 2005 | 06:25 AM
bardabe's Avatar
Bad Speller
or the slave cylinder as weill
Old Sep 13, 2005 | 04:54 PM
MarkieMark's Avatar
thanks! i'll check up on those.
Old Sep 13, 2005 | 05:25 PM
CanyonCarver's Avatar
Jack Of All Trades
Like emo said... sprung release? Under the dash there is an assist spring that helps the clutch pedal return............. HERE
Maybe it's broke or off.
I have seen hydraulic cylinders that leak past the main seals, but know leaks outside of the cylinder. I've also had an issue on my Z with the clutch when I'm trying to go really slow up a rough dirt road. If I use the clutch too much, I loose about 3/4 of the pedal. Meaning that the pedal will go thru 3/4 of it's travel before the clutch starts to disengage. That's a definite sign of a leaky cylinder. All is well after a few continuous pumps.
Yardjass
Apr 8, 2012 07:58 AM
snwbrderphat540
28
Apr 29, 2008 11:43 AM
anyrug
Mar 11, 2007 08:05 PM
Fourtunata
Jul 30, 2006 04:31 PM
jbaran300z
Nov 10, 2003 04:02 PM
