Compression test
Old Jan 3, 2012 | 06:24 PM
3riCJbOi's Avatar
one sound fits all
Compression test
Hi everyone. I did a compression test today on my 91 NA Z32 and I got a reading of 145 - 155 on all the cylinders. So that should be decent right?
Also I read I was suppose to do the test with WOT
but I just cranked the engine without opening the throttle.
Twinturbo.net said that WOT would have a slightly higher compression reading.
Is that true?
would that mean if I did do it with WOT my readings would be a little higher?
should I do another compression test with WOT?
Old Jan 3, 2012 | 06:44 PM
Compression should be around 180psi if I remember right.
Is that true?
Yes.
Old Jan 3, 2012 | 06:59 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
WOT isn't going to make that much of a difference - your engine isn't choking while cranking.
Old Jan 4, 2012 | 03:06 AM
I've seen about a 5psi max on average rise between wot and not. So no big deal.
Old Jan 4, 2012 | 10:24 AM
3riCJbOi's Avatar
one sound fits all
I did another compression test with wide open throttle and I got about 150 to 155 across all 6 cylinders. And no my engine doesnt choke while cranking. its has a nice constant crank to it. I think thats a pretty good reading. I was considering a rebuilt but since compression isnt bad I dont really need to huh?
thanks for all your responses.
Old Jan 8, 2012 | 10:22 AM
... that's good compression for a Twin Turbo. For a non-turbo, you're 25-30psi low (as hoov said, it should be in the ballpark of 180). How is that a good reading?
Old Jan 8, 2012 | 01:15 PM
3riCJbOi's Avatar
one sound fits all
Do you think I should consider rebuilding the engine?
Old Jan 8, 2012 | 04:23 PM
Unless your gas mileage is in the *******, or it runs like crap I would just drive it.
Old Jan 8, 2012 | 09:36 PM
What hoov said - just drive it. It is a non-turbo. Of course, you could replace it... with a twin turbo engine.
Old Jan 9, 2012 | 12:18 AM
3riCJbOi's Avatar
one sound fits all
Gas mileage isnt great but its not bad either it is a Z
getting a new efi harness along with new injectors cause 3 crapped out. After that it should run great. No leaks or anything soo yeah not bad for 180k
Old Jan 9, 2012 | 12:19 AM
3riCJbOi's Avatar
one sound fits all
I probaby get 300 miles a tank
Old Jan 9, 2012 | 12:54 AM
And your complaining? ****, I can't get more then 270 out of my TT.
Old Jan 9, 2012 | 11:36 AM
3riCJbOi's Avatar
one sound fits all
well thats true I always get somewhere around 280 to 300 full tank. Stock 270cc injectors
Old Jan 9, 2012 | 08:18 PM
I promise your 270 twin-turbocharged miles are far more enjoyable than his 300 miles.
Old Jan 11, 2012 | 10:17 AM
3riCJbOi's Avatar
one sound fits all
Got the JWT Pop Charger installed along with the new EFI Harness and 6 new injectors in and started my baby up and it ran like a champ. Quick response and acceleration. And this morning started it up again and smelled gas T.T... The #6 cylinder injector seal was leaking.... Now gotta take apart everything again and replace that ONE seal. Its gonna be a long *** day.
Old Jan 16, 2012 | 11:06 AM
SLE-PR's Avatar
Check My Compression Readings....LOL
Its a 1990 NA with 93k miles (on the Odo, anyways). It wont start at all below 50*F, checked everything I could and decided to do a Cold compression test the other day on +26*F day and these are the results between Hot and Cold (PSI Readings)
-1 168 Hot - 65 Cold
-2 160 Hot - 45 Cold
-3 180 Hot - 65 Cold
-4 160 Hot - 55 Cold
-5 160 Hot - 40 Cold
-6 120 Hot - 30 Cold
Small wonder it wont start, I think a Cold Compression test can tell you dam near as much as a Hot test in the reverse aspect of things.
Well, I finally got my JDM swap done and new EFI harness in and this car runs like a car should. I'm hoping I got a good one cuz I couldnt find anything wrong with it on the engine stand doing all the pre-install electrical and mechanical tests, hell, I even got 170 psi/cyl. using a 18" swing bar on the crank doing a poor mans compression test.........now to finish the TT.
odebiyi
Jun 20, 2012 06:47 PM
wild_maxx
Oct 8, 2006 12:32 AM
speedgato2
Jan 12, 2004 08:57 AM
86ZXTurbo
Jul 17, 2003 01:36 PM
Zwolftech
Apr 24, 2002 06:05 PM
