Can I get new connectors?
Old May 22, 2014 | 08:53 PM
dennys93na300z's Avatar
I posted a while ago about my high rpm miss and engine stalling. It turns out it was the PTU. I bought the replacement from Courtesy Nissan, best price I could find with the PTU and new wire harness. My issue is, the old connectors coming from the car's wiring harness are cracked and brittle from age and heat-and I didn't realize this when I started scrubbing them to clean all the corrosion off the connector. Is there a place that sells replacement connectors for your old wiring harness coming from the ECU? I can only find the whole wiring harness when I look, or I do find some but not for a 1993. Right now they are taped/zip tied together and still the connection is bad...making my new PTU work as good as the old one.
Old May 22, 2014 | 09:42 PM
PredatorZ's Avatar
Fricfrac
Fricfrac has assembled a connector kit he sells, mostly for connectors like the MAF /MAP, TPS, fuel injection etc. He might be able to help you.
Fast240Z
Mar 3, 2014 04:51 PM
TaterBiscuit
May 8, 2012 05:13 PM
islandtuner242
Dec 3, 2010 10:52 AM
CWHammer
Oct 18, 2005 03:21 PM
Dec 16, 2002 11:58 AM
