Bad Idea? Probably.
Old Dec 18, 2009 | 05:20 PM
BlueKitsune's Avatar
Intrawebz Wizard
Bad Idea? Probably.
Ok well This is pissing me off a little. The old owner of this Z I've been working on, installed a TT into a N/A 2+2.
Well They used the stock efi harness for the N/A so the Z is stuck at 6PSI Ontop of that they poorly installed a front mount IC and When I took the engine out I had to remove the IC pipes. Now I cant get them back in and I'm VERY temped to just feed the turbo out right into the intake with no IC
Other then a loss of HP will that ruin the engine? If not I'm probably gonna do that. as it honestly looks like that got a random IC then they hacked away part of the front frame to make room for the press bent exhaust pipes for IC piping. (hell they even took a chunk out of the back of one of the turn signals!)
Old Dec 18, 2009 | 06:08 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
You WILL blow your engine in time if you run without intercoolers. You are vastly underestimating the effectiveness of such a device on the Z32 - a good intercooler will cut down intake temperatures by over 100 degrees. (Data in my intercooler writeup - https://www.zdriver.com/forums/300zx-z32-tech-tips-273/intercooler-writeup-long-19694/... look at the temperature differences between stock and aftermarket intercoolers. Imagine not having one at all.)
Get sidemounts.
Old Dec 18, 2009 | 06:42 PM
KasbeKZ's Avatar
Pr0n Addict
Not to mention the owner being pissed that the ic he bought isn't there
Old Dec 18, 2009 | 07:05 PM
Intrawebz Wizard
He didnt buy the IC. Ugh **** I hate this car its EXTREMELY jerry rigged I'm shocked the piece of **** even ran before he got it! N/A harness thats be spliced into so many times, and piece of **** alarm system that didn't even work, a shitty boost gauge that always read -10 no matter what. a ****ed up TT engine a blown auto (now a 5 speed) and theres oil coming from the passenger turbo.
And so far. I really hate Z32s. Very poor design IMO.
Old Dec 18, 2009 | 08:44 PM
It's actually the most advanced design of any Z, and to have everything fit together as it does is a marvel of engineering, you just happened to accept a project that was way out of your league.
Old Dec 18, 2009 | 08:56 PM
KasbeKZ's Avatar
Pr0n Addict
Bad conclusion there. Someone f-d the car up and you blame the design... The z32 is nothing but amazing once you get the Hang of it. Meaning: read 5 times more than you think you have to before you do it
Old Dec 18, 2009 | 08:58 PM
PurePontiacKid's Avatar
i felld offa mai trike
it's a retarded design because it's difficult to work on, plain and simple. I'm sure the car performed extremely well because of the way it was designed, but for working on it, it's very poorly designed.
Old Dec 18, 2009 | 09:07 PM
I have no trouble working on it.
And by your logic, Lamborghinis, Porsches, Ferreris, etc are all retarded designs, too, right? Because some of them require engine removal for the most mundane repairs...
Stick to your domestics and classics if you're not comfortable with compact engineering.
Old Dec 18, 2009 | 10:06 PM
Intrawebz Wizard
Seconded on that one!
Actually Yes! Hence why I will stick to Classics! S30 S130 Are my fav! lol I respect the Power they put out and stuff. but Bad design to have to tear the car apart to do little things. Tho Porsche, I heard, gives you an entire kit to remove the boxer engine from the new 911 and its like a 30 min thing to do. if this is true I have no idea but that was a smart idea sense you have to remove the engine on that one to do a lot of stuff.
Anyways This isnt my Z, I'm working on it for my friend. And I shouldn't talk down to much about it as I have worked on an N/A 300ZX and its not TOOOO bad to work on. Tho the Maintenance for the engine is the most annoying part about it for me. Having to remove like the entire top half of the engine just to get to a stupid knock sensor?
Old Dec 19, 2009 | 04:13 AM
napoleonzheking's Avatar
F5 Hero
HUGE second..... I have no problem working on mine (whether it's my 5 speed TT slicktop, or my auto NA 2 + 2, my friend who has a 2 + 2 auto converted to 5 speed (which I did a lot of work on, or my my bestest friend in the whole wide world's na auto 2 + 0 whose car has been in my garage while he's at AIT for the army, what i'm saying is, i've worked on every breed of Z32) )... I've come to the conclusion that you and the OP are lacking the most important tool any one's tool box (whether mechanic, carpenter, or any other profession requiring a tool box).... and that my friends is PATIENCE.... I remember when I didn't have that tool, I'd get pissed when I couldn't get stuff out, and just start cutting it out... (intake pipes, AC lines, PS lines)... ended up costing me over $400 in the long run.....
Now that I have this vital tool, and have actually LEARNED THINGS (not saying you guys haven't learned anything, I'm just saying), I can do an NA to NA swap in < 4 hours (not counting if it has a stock exhaust still on that is 15+ years old that usually requires old ruty bolt cutting to get it off, but I have the proper tools for that now....)
and asking if you can run without an IC is like asking if you can run without an oil cooler, which that question was posed to me by a local Z32 owner and I put it like this... Would you put your oil in the microwave before you put it in a car and ran it....... same situation basically....
sorry for the rant, to sum it up, yes it's a bad idea...
also, you don't have to remove the top half of the engine to get to the knock sensor, basically only the UPPER intake manifold (plenum)... you can get to the knock sensor after that with the right tools...
Old Dec 19, 2009 | 11:20 AM
Intrawebz Wizard
Ok ok ok.
Oh did I say someone already bypassed the oil cooler on this Z as well? Cuz they did sense before the current owner got the car.
Anyways for now I'll put back the IC piping I still cant believe they used exhaust piping tho. And will an aftermarket autotranny oil cooler work or would that probably be to small? I remember he let me drive the thing and I had to pull over like every half hour just to let the damn thing cool down as it would nearly always hit the red.
Old Dec 19, 2009 | 05:25 PM
Lesnocker's Avatar
Thats a turbo for ya! honestly Ill swap it over to a n/a. Name me one company from 79-09 that had a dependable turbo. Just a time bomb waiting to blow at the worst possible time. That and were talking what 8-9 psi ? 20-40 hp???
Old Dec 19, 2009 | 05:36 PM
uhh, Mitsu, Scoobaru, Nissan, Toyota, Mazda just to name a couple...
Old Dec 19, 2009 | 07:38 PM
KasbeKZ's Avatar
Pr0n Addict
the z32 isn't necessarily hard to work on, but it is hard to figure out how to fix it and upgrade it properly. you can't just bolt a turbo on it like it's a honda. but i basically learned most of what i know about working on cars with the z32, at age 17. f-ing fantastic car. people say what you want about it but i'll do whatever i can to have one for the rest of my life
Old Dec 20, 2009 | 01:49 AM
Who are you and where do you get your information? On most turbo applications, a single psi is around 10hp. The Z32 got 78hp from 9psi (8.67 hp/psi). You'd be hard pressed to get an NA Z32 to produce 300hp, and even then, all the TT would have to do is add an intake and exhaust and its out of the horsepower range of the NA. Upgrade the turbo and the parameters change considerably - I got nearly 20hp per psi from my GT2530's.
And with the list of reliable turbo cars, add Porsche, Ferrari, Bugatti, Mercedes, BMW, etc.
Darkmann
Apr 7, 2008 10:49 PM
Heat Rave R
May 2, 2007 04:53 PM
entropy31
Apr 15, 2007 03:41 PM
duowing
Feb 8, 2006 08:46 PM
snwbrderphat540
Oct 14, 2005 02:16 PM
